What year of Windstar
Discussion in 'The Garage' started by BlackDog714, Sep 29, 2004.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Do you look for for the fans?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Mine was off a '93. I believe that there is a wide range of years that works.
  3. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    mmmmmm, Could be. Its been a year and a half. /forums/images/graemlins/tongue.gif
  5. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Well thanks, the years are 95-98. I am planning the next phase of the wiring on my truck, which will change the diagram I have on there now. The large fan is in fact two speed. The fan goes into hight when voltage is applied to both hot connections. I'm planning on adding a 3 relay to manually select high on the large fan. Also adding a switch to cut out the ignition pwr to disable the fans (for water crossings mainly.)
  6. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    I also went down to the ford dealership and picked up the connectors off the wire harness side for that year windstar. They come with 6 inchs or so of wire so you can spice them right into your existing wiring. By doing this I got a good solid connection at my fans (these connectors have a big locking clip on them. No worries of them coming disconnected bouncing around.) And the fan wiring now looks factory. The connectors were a couple bucks each. Once I get some time I'm gonna update the write up on my webpage with some new pictures and if I can find the part numbers for those connectors, I;ll put that up as well.
  7. BlackDog714
    Jun 8, 2002
    260
    Indiana
    I got mine for $40 at the junk yard and it came with the connectors.
