what years for the 14 bolt semi floater?
Discussion in 'The Garage' started by bad_bo_ti, Sep 26, 2004.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    what years were the 14 bolt sf 6 lug axles on, i am going to start calling junk yards tomorrow and need to know, its going on a 93 chevy 4x4 1/2 ton. and will i need a conversion u joint for this, and will spring perches line up? thanks, chris
  2. mrk5
    Apr 20, 2004
    12,330
    1,038
    Northern Colorado
    My brother-in-law has one that came factory on his '91 Z71 1/2ton pickup.
    I would guess the perches will line up.
    There's probably someone that can give you better info, but hopefully this will get you started.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i know a buddy of mine had one in a 88 3/4ton 4wd.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    they only came in the IFS rigs so the perches will line up. I am pretty certain 88-98 chevy's had them. Like noted some Z71 1/2 tons, some simply heavy duty 1500s(no idea what makes them so special, guess trailer package), and 2500 Light Duty rigs have the rears. My dad had 2 2500 LD rigs. an 89 and a 95 both had 6 lug 14 bolt semi floaters.
  5. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Nope, also came under some pre 88 trucks, and a lot came in 3/4 ton 4x4 burbs. /forums/images/graemlins/waytogo.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I meant the 6 lug Semi floaters /forums/images/graemlins/wink.gif My 89 3/4 ton burb has a 8 lug semi floater 14 bolt. As does my 97 3/4 ton pickup. As did my 95 K2500 /forums/images/graemlins/smile.gif.
  7. bad_bo_ti
    1,027
    OhiO
    thanks guys, do you know what ratio was in most of the newer ones? i have 3.42s in mine right now.
  8. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    The sf14b that came in my 90 suburban came with 3.42 gears.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    same for my 89. but both of my dad's 6 lug ones were 3.73. My 97 is 3.73 and my 95 was 4.10. See in the 90s you could actually pick your gear ratio and it made a difference, nowadays if you want to buy a new rig with 3.73 gears they look at you like you are psycho and tell you it will cost you a couple grand more cause you have to special order it /forums/images/graemlins/rolleyes.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Actually, no. You can order a new truck with a number of gear ratios at no additional charge.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah but its cheaper if you take the truck already sitting on their lot and go out to a chevy dealer. You will find like 75% 4.10 gears at the least I bet.
  12. bad_bo_ti
    1,027
    OhiO
    just called a couple bone yards today and they want 650-675 for one /forums/images/graemlins/yikes.gif
  13. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I'd say semi-floaters are probably worth like $200.00 unless they *REALLY* don't have to be freshened up? /forums/images/graemlins/screwy.gif
