what york compressor
Discussion in 'The Garage' started by 79k20350, Jan 8, 2006.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    I found a few. ones from a international...would this one work ok, its a hd. sorry for the newb type post but im just not sure and i couldnt find anything specific in search. Whats an ideal compressor to look for? Thanks guys
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I got mine off of an 80s chevy van with the brackets to mount it above the water pump.
    Ira
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    another question, i am going to be doing this on a 6.2 w/ turbo. are there any brakets to just bolt it up like sandawgs?
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    also would just a regualr 6.2 compressor work. whats the differance between a york and regualr ac compressor.
    (can you tell im new to oba?:D:doah:)
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The York will oil itself, the other type of compressors use the freon for lubrication.
  7. divorced
    Jul 20, 2004
    5,115
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i can find plenty in line oilers so i can mount on on the inake side, use a standard 6.2 compressor, and then a oil water seperator on the other side....hmmm that may be the way to go. what the differance in airflow beetween a standard york and a stock type ac compressor? thanks agaian guys!:D
  9. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Their are atleast 3 different york compressor displacements. Check out www.onboardair.com for how to tell the difference.
    You can run a standard oiless AC compressor with an inline oil source but they are not known to last as long as yorks. One of my clubmembers runs a Sanden with a inline oiler and has got 2 seasons out of it so far. Not bad considering they are easy to find and bolt right on. I think the most wear would come from start up when the oil has settled and their isn't any suction yet to oil it.
    As to finding the big 10cube York I have the easiest luck pulling them out of Jeep Grand Wagoneers. Every junkyard has a few waggys and they all seem to use the big York. Just make sure to get the first foot or so of line from it because they use a weird thread on the top. Easier to use the stock line and then convert to NPT then to find a fitting for it.
    Here is more info on identifying a York
    http://www.kilbyenterprises.com/york-manual/pdf/6.pdf
  10. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I know a guy that has a 350 vortec in his 4Runner. He is oiling the compressor then serperating on the back side. Works but alot of extra hasle.
  11. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Hassle yes and no... easy to do, and is a direct bolt on, and is all factory parts... belt setup easy, as is plumbing (not saying a york isnt for plumbing) as for expense it looks like depends ing on where you get your pump its maybe a lil more expensive... I really want to compare cfm on a stock gm ac unit to a york. that will prolly be what my desicion is based off of. if they are close/ the same than ill prolly go with the gm unit.
