what you think about spools
Discussion in 'The Garage' started by screamer*145, Dec 9, 2003.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    I am thinking of getting one, yea my truck does see more pavment, but these are my reason's for geting one over a any other locker.
    1. they are cheap
    2. they are strong
    3. best traction
    You may be thinking that I will break axles if I turn with power but wouldent that be the same with any locker and I am not talking about slectable lockers. I would get the chirping the diffrent wheel speed and maybe a little extra tire wear, right? any info will help! /forums/images/graemlins/thinking.gif
    Thanks! /forums/images/graemlins/thumb.gif
  2. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    spools are cheap, strong etc but i wouldnt run one in a rig that is used on the street. some people do, to each their own. If you have a ff14b, just get a detroit... its plenty strong and ff14b detroits are purdy cheap. Good thing about the detroit is that it has a little give in it, so on not-so-tight corners etc it doesnt chirp at all.
    j
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    No...Lockers are designed to disengage during a turn so the tires can turn at a different rate. Not possible with a spool.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You have a 12 bolt which is on borrowed time already. Adding a spool will likely finish the axle splines.
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    A few years ago, a buddy of mine bought a '72 Chevelle with a mini-spool in the 12 bolt. After twisting the axle tubes in the housing, breaking 3 shafts, and fragging the R&P twice, he had me yank it out and put the spiders back in.
    Spools are just hard on parts.... /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  6. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Not to hijack...but what if it was in a front Dana 44 axle that had manual hubs and a part-time kit in the NP203, this wouldn't be bad since the front wheels spin independantly on the street right? /forums/images/graemlins/truck.gif
  7. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    1. they are cheap
    2. they are strong
    3. best traction
    If ya think you can learn to drive with one, then go for it. The reasons I am going to a spool are what you listed, but I don't want to play games with something unlocking and locking. Either go all the way or stay home /forums/images/graemlins/thumb.gif
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Right...you just won't be able to turn on the trail and will break shafts all the time. I think any locker or spool in a 1/2-ton axle under a full size is a bad choice. Keep it open and it will live longer.
  9. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    If you are gona go spool, why not just weld it up and see how you like it. I have a good friend and I ride in his rigs quite often and so far I haven't been impressed with detroits on the street at all. The little give that they have isn't enough. If you have to accelerate through the corner you can expect a bang. Then you let off and it unlocks. Jut too unpredictable. Weld it up especially if you have a 14 Bolt.
  10. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    with my luck, the 1st time I wheeled with a spool in front, something in the rear axle would grenade and I'd have to drive it home in 4wd on just the front axle... have fun with that if ya got a spool up there. I really dont see the point in running a spool in the front of any rig, in the rear I can see it, but the front...esp a 1/2 ton front?!? negative!
    j
  11. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    this is just a ?
    does a locker ever really disengage? or do they just allow one wheel to spin faster than the other, but never slower than the input speed? (if that makes sense) [scratches head]
  12. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Depends on the locker a detroit locks up when there is any torque input unlike an arb which can be switched from full lock to fully open (very nice but very $)
  13. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    for one, the spools for the rear (where did you get front from) and why weld the gears only to see if I like it because if I dont I have to buy new spider gears or if I do like it the welds are not as strong as the spool, and would a 14ff be able to handle a spool with no bigger than 36's? /forums/images/graemlins/thinking.gif
  14. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    a 14Bolt FF and 36's should be find with a spool IMO... but im aginst it also... they are really fun and you will love it for a wile.. but your tires will be BALD in no time and you cut down on your turning radious(on the street)
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    But they don't make a spool for the 14 bolt full floater, so it doesn't matter.
  16. 6335
    6335 Registered Member
    Aug 14, 2002
    67
    I have a mini spool in the back of my 86 with a 12 bolt. It is 95% used just in the sand, it has held up great in the sand and gets lots of traction, just like I planned. BUT- That 5% that I drove it on the highway with just a little show off, 425 HP , 35" boggers the ring and pinion exploded! I think there great in the sand or strictly off road but they are not meant for the highway.
