What you wish you would have put on your tire carrier!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KrebsATM02, Aug 6, 2001.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I'm building my tire carrier this week and i'm trying to incorporate everything i want on it. It really won't be hard to add onto it later on though. I'm starting off by using a trailer spindle and hub. I'm cutting off the ring with the studs through it. Then i'm using 2x2 box for the frame. I'm putting the license plate on it with a light, a backup light, a hi-lift jack mount, cb antanae, and the tire obviously. What else would ya'll recommend. I think a jerry can is kinda useless on a blazer with a 31 gallon gas tank. Any suggestions or hints? Thanks Doug Krebs
    Doug Krebs<P ID="edit"><FONT class="small">Edited by KrebsATM02 on 08/06/01 09:33 PM.</FONT></P>
  2. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    D-Rings For Tow Strapps.
    A Big Hammer Can Fix Anything ..
  3. KrebsATM02
    Mar 21, 2000
    553
    anyone else?
    Doug Krebs
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I would do at least 1 Gerry can holder. If you don't feel the need for gas than use it for 5gal of water.
    .02c
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    KEG holder with built in refrigerator... LOL! Other than a couple D-rings and a hitch reciever, I think you have it pretty much covered.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers... and it's still not BIG ENOUGH!!
  6. lugnut
    lugnut 1/2 ton status
    Aug 3, 2001
    268
    North Carolina
    A spinale &amp;hub to match your front axle. Instal wheel bearings, races &amp; locking hub. You will have spare parts without taking up room in the truck. Just a thought.
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah, what Steve said, you can never have too much water. Maybe make the bumper into a air tank?? Or make some storage inside the bumper. Just a idear
    <a target="_blank" href=http://www.k5.rockcrawler.com>Click here to see my K5</a>
    *<font color=red>under construction</font color=red>*
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I'm liking lugnut's idea of using a regular spindle &amp; hub as a mount, so you've got a spare.
    It's always darkest just before it goes pitch-black...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  9. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    if you have an onboard compressor you could put a fitting into the bumper tube(s) and hook the compressor up to it for an onboard storage tank, might just speed things up when its time to air up or using the air tools, you will need a pressure regulator though and a kick off switch for when the pressure gets to the the set limit
    this is an idea i plan to try when i build my carrier/bumpers, if you tie anything that can hold air on the truck all together you should be able to get alot of work done faster because the compressor could keep since it has time to recharge the "storage tanks" when you set the tools down to hand thread that next nut or whatever
  10. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    How about a big fat CK-5 sticker!!!!!! And I would put the jerry can/cans on it. Maybe you can make extra cash refueling Heeps on the trail!
    Keep it simple!
