What're all those small hoses for on poly gas tank??
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ErikH, Mar 10, 2003.
  1. ErikH
    ErikH 1/2 ton status
    May 15, 2001
    112
    Southern California
    What\'re all those small hoses for on poly gas tank??
    I'm in the process of replacing the sending unit on my poly gas tank (poorly installed by previous owner), and I was wondering what all the smaller hoses were for... They seem to lead to strange places and I want to make sure water doesn't find its way into my tank again. Can I plug anyone of them up? Thanks for any help
    -Erik
  2. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    Re: What\'re all those small hoses for on poly gas tank??
    How many do you have? My guess would be a vent/ evaporation line and maybe a return line for a fuel injection conversion.
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Vent/evaporative stuff is my bet. My 40 gallon tank has three vent tubes, one return tube, the pickup tube, and the filler tube.
    Do *NOT* plug the vent tubes. Doing so will give you tuning fits. Hook them up correctly to the liquid/vapor separator and ensure that the liquid/vapor separator is correctly hooked up to the charcoal canister.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Mine has a bunch too. I haven't counted them all but there are about 3 that go up the tube by the fuel filler (no idea what for?), and a few that go to the (now non-existant) carbon canister. I bet there are a bunch you can cap off! Just make sure you leave at least one vent line.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    As long as you're running a vented gas cap, and that's the big IF, why do you need ther extra vent on the tank? /forums/images/graemlins/confused.gif
  6. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    I plugged all but the fuel line and one vent line on my poly tank.
  7. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    there is one vent that goes next to the filler, that's so your tank can breathe when you fill up otherwise it would burp on ya, one is the pickup, and the other is probably a return.
  8. ErikH
    May 15, 2001
    112
    Southern California
    Please tell me more about this canister and water separator... Which line(s) go to the canister (which I removed, oops), and what's the proper hookup. I have a 21-gal poly tank with three connectors (one larger for the return and two others -- one goes to the mystery riser behind the left fender; and the last line goes somewhere... maybe to the non-existent canister???). Thanks for your help!
    Erik
  9. Steve_Chin
    Mar 6, 2001
    1,126
    There shoul;d be a minimum of three vent lines. One bigger one that goes to the top of the filler neck, and two smaller ones that route from either side of the fuel tank to the liquid/vapor separator (the "tube thing" behind the filler neck). The reason that there are two vent lines attached to the liquid/vapor separator (I'll call it the standpipe from here on out) is because a submerged vent line does not vent well enough (it's basically hydrostatically locked). If the truck has a nearly full tank and is tilted to one side, the opposite vent tube is functional and will allow air into the tank as the fuel pump pulls fuel out of the tank.
    The charcoal canister is a pretty simple filtration device that separates unwanted fuel vapors out of the air that is expelled from the tank (and in some models the carburetor). Those vapors are collected for ingestion into the engine when it is running. It does not a thing to hurt performance and can help make a steel gas tank and steel fuel lines last much longer because it also filters moisture out of the air that is vented into the tank.
  10. ErikH
    May 15, 2001
    112
    Southern California
    Ah ha! But wait... You say two of the three lines go to the standpipe and the third goes to the top of the filler neck. Sounds logical, BUT which line feeds the canister up front?? Is there a "T" somehwere in one of the two smaller vent lines? Again, thanks for the help!
    -Erik
    There shoul;d be a minimum of three vent lines. One bigger one that goes to the top of the filler neck, <font color="blue"> and two smaller ones that route from either side of the fuel tank to the liquid/vapor separator (the "tube thing" behind the filler neck)</font>. The reason that there are two vent lines attached to the liquid/vapor separator (I'll call it the standpipe from here on out) is because a submerged vent line does not vent well enough (it's basically hydrostatically locked). If the truck has a nearly full tank and is tilted to one side, the opposite vent tube is functional and will allow air into the tank as the fuel pump pulls fuel out of the tank.
  11. Steve_Chin
    Mar 6, 2001
    1,126
    Nope... The standpipe has three nipples. Two lead to the fuel tank vents, the third leads to the evaporative canister.
