whats a d-60 worth...?
Discussion in 'The Garage' started by tomford, Nov 20, 2006.
  1. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    hey guys
    i have a few quick questons, i might be getting an 84 pickup how do i tell if it's a d-60?. it got 8 lugs and a 14bolt ff
    also whats the d-60 and 14 bolt combo worth?
    how bout a d-44 whats the going rates?
    tom ford
  2. goldwing2000
    goldwing2000 Guest
    If it's a 3/4-ton, it's probably a 10-bolt. If it's a 1-ton, it's a D60.
    Easiest way to tell is to see if it has king pins (D60) or ball joints (D44, 10-bolt)
    A good D60 is worth from $1000-$1500. Add another couple hundred for a good 14bff.
    A good front D44 is worth about the same as a 14bff.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You can tell a D60 front by King pins rather than ball joints, the front webbing to the right of the difff cover will say 60F. Around these parts aD60 front goes for around $1000.00-$1200.00. If it is only a 3/4 ton 8 lug D44 or even a 8 lug 10 bolt it's only worth about $150.00-$300.00 max, the higher side if it has the gears you need.
  4. tomford
    Jan 19, 2006
    921
    7
    New Hampshire
    wadda bout a corp. 14 bolt
    tom ford
  5. goldwing2000
    goldwing2000 Guest
    :wink1:
  6. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    dime a dozen i paid $50 for mine from the local junkyard
  7. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    I paid $250 for mine... wouldv'e paid less if I pulled it out myself but bad timing (on the way to work) and didn't have tools and extra people. So ended up paying more to have the junkyard guys pull it out for me and load it up the next day..... it was in pretty decent shape, no rust but covered in grime due to the fact it stayed under a 3/4 ton '83 Chevy Cheyenne pick up.
    I originally wanted only the axle tubes and housing so I can do a complete rebuild but the owner wanted the whole axle gone so I didn't bother to put in a fight for less $$$$$$$.
  8. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    I was talking about the 14BFF by the way.... Forgot to add that...
  9. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    without much luck locally, i paid just shy of $1200 shipped for a SFW gm 60 with 4.56's from a vendor on pirate. more than i wanted to pay but...meh...
    phew! i was gettin real jealous for a second there lol.
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    i bought a fully running 1 ton for $500.... d60 front and 14bolt rear... 4.10's though...... but yeah that was a score.. it was lifted too 7" and 38's...
    after taking all the parts I needed I gather I paid about $125 for the front axle...!!!!!
    anyway... d60 fronts are expensive here too... $500-$900 even for a dually and needs rebuilding.... however the 14bolt ff is so cheap... on junkyard around here said $38 for one.... and dont care what gears are in it!!!!!!!!!
  11. tomford
    Jan 19, 2006
    921
    7
    New Hampshire
  12. goldwing2000
    goldwing2000 Guest
    That's a rusty-ass 10-bolt. I wouldn't pay more than a couple hundred for both axles on that truck.
