whats a doubler?
Discussion in 'The Garage' started by K5Redneck33, Apr 25, 2003.
  1. K5Redneck33
    K5Redneck33 Registered Member
    Aug 31, 2002
    47
    INDIANA
    i know this prolly sounds stupid to all you thats been in offroad for a while, but i have no idea what a doubler is? i see people talk about it and stuff but i am just wanderin like the basic of what it is? /forums/images/graemlins/k5.gif
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    A doubler is simply a combonation of a 203 and 205 transfer case. You use the gearbox of the 203 in front of the regualer 32-spline input 205 with a special adapter and you have the option of 1:1, 1.96:1, 2:1, and 3.96:1 ratio reductions. The normal 205 has a 1.96:1 reduction in low and the 203 has like a 2:1 reduction in low...add them together and you get 3.96:1...plus, the entire unit is relatively compact /forums/images/graemlins/thumb.gif Check out ORD for more information...
    Chris
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    To explain what Chris just said in a different way:
    "It a thing that makes your money go FAST, and your truck go SLOW..."
    /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/eek.gif
  4. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    x2, not +2 (hence the name "doubler"). It's not much diff between 3.96 and 3.92 but if you use a case like a 241 (4.72 vs 5.44) or 3:1 gears in the 203 (4.94 vs 5.88) it will start to matter. If you start talking Klune-V or 4:1 gearsets that are out for some of the Toy & Jeep cases the jumps are bigger.
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    can you make a doubler out of any t-cases, like a 208 and a 205 or does it have to be a 203 &205?
  6. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    The advantage of using the 203 and 205 is that it's all gear driven so there are no chains to wear out. The part they use off the 203 is all gear driven, and the 205 is also. Supposed to be really tough, but kinda expensive.
