Whats a good caliper for driveline brake?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wally81k5, Mar 20, 2003.
  1. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    Hey everyone, while im in the mood for makeing stuff. Thumper suggested a driveline brake. He said snow machine calipers work as all the linkage is mech. Has anyone made their own? I am going to... $300 is a bit much for me... since my truck was 200 CDN.
    Ryan
  2. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    PS: Why can't i just make the disc out of 1/8 steel and clean it up and maybe even drill some fancy holes so it looks expensive?
    Ryan
  3. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    anyone?
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    It would have to be perfectly round and balanced so a store bought rotor would prob be easier.
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    perfectly circular wouldn't be too hard- just get it real close then take it to a lathe, even a good wood lathe would work.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Ryan
    Well, if it's the caliper you can make one that is mechanical. As for the rotor, you could make one if you have a lathe, or a CNC mill.
    If I had this kind of equipement I would probably make most of my parts.
    I usually go to yards and look around and find something that works for me, and adapt it with some fabing.
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    a lathe can't be THAT much.
  8. Grim-Reaper
    7,385
    Atlanta
    Ryan
    Go find a FJ 40 toyota in the junk yard. They came that way. Older ones were a drum and newer are disc. Not sure of the year they changed.
    Wilwood sells a mechanical caliper and rotor for just this application.
