Whats a good off-road carb
Discussion in 'The Garage' started by gm500hprat, Jul 20, 2006.
  1. gm500hprat
    gm500hprat 1/2 ton status
    Feb 28, 2005
    196
    anaheim, ca
    Title says it. For those of us that cant afford fuel injection or engine setup will not work for Propane conversion. I have a BBC 468. Right now it has a crappy Holley that some old hack sold me that came off an old mustang or something and he shaved off the choke and all that stuff so it looks like a race carb. Anyways its a 500 hp engine has a decent cam with nice loap. the existing carb sucks offroad engine stalls over 2-3 ft whoops going slow or fast. Lets bring the ideas and let me know why. Keep in mind it's a big block so I'll need cfm's above 750.
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    The quadra jet is the way to go if you cant do FI.
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i second the "quadgraBOG" on that one, you will lose a little HP but it will be better than your holley in your situation
    LUKE
  4. gm500hprat
    Feb 28, 2005
    196
    anaheim, ca
    quadrajet's only have like 700 cfm right ? I've had quadrajets when I had my 350 and it definately ran better than this holly. But I dont think it will cut it for this engine.
  5. gm500hprat
    Feb 28, 2005
    196
    anaheim, ca
    anybody have any luck with the carbs that edelbrock and holley put out for offroad use?
  6. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i have the truck avenger, no problems at all and have never had it bog on an incline. definitely a good buy.
  7. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Off the top of my head, I think they are around 770 cfm. Remember those secondarys are huge. Also, it's not just cubes, what's your top rpm?
    Your second choice would be the holley truck avenger, in my opinion.
  8. gm500hprat
    Feb 28, 2005
    196
    anaheim, ca
    Redline is 7500 rpms. Usually shift around 6800-7000
  9. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Well, I'm with you on the big carb idea, that's a lot of cubes and alot of rpm's.
    You could probably use around 850 cfm or more in that beast. I'm unaware of a carb that size that would be a great choice for off-road.
    Theres a carb shop guy down in Huntington Beach (sp?) that can probably help you, I'll try & find him for you.
  10. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Q-jets came as either 750 or 800 CFM (except the Edelbrock ones). The 800 CFM Q-jet is the best carb for your application.
  11. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Good call low rider, I forgot about that one.
    For more info in your area, call 909-947-3575. Bob & george, The Carb Shop.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Dig into the race-dezert bbs. There are carb shops that specialize in carbs for off road racing. Most of those will be Holleys. C&J i think is one such name.
    Short of spending that kind of $$$ I think the Q is the best idea. Extend the float bowl vent up to within 1 tube diameter of the air cleaner lid, but don't go any closer. Wouldn't hurt to put a "baloney" cut on the top of the tube facing away from the venturies.
  13. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
  14. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Took over a 45 degree incline to stall my Holley TA. Very happy with it so far.
  15. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
  16. gm500hprat
    Feb 28, 2005
    196
    anaheim, ca
    vacuum secondaries.
  17. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    I actually had really good luck with my Edelbrock Performer 600 w/ off road needles and seats. You'd need a bigger one, but just my .02.
    But one thing to note: AFB style carbs are notorious for getting dirt and crap in the float bowls, and I have to clean mine out every now and then to keep it happy.
  18. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    How about a predator?
  19. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I was thinking the same thing
  20. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    My friend's 500 caddy is running a 850 cfm quadrajet (original caddy carb)...has an altitude compensating aneroid in it to adjust fuel mixture at elevation. Its probably the best carb for a big block, offroad application.
