Whats a "Gov-Loc" *stupid question*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84silverK5, Dec 18, 2001.
  1. 84silverK5
    84silverK5 Registered Member
    Nov 28, 2001
    65
    Hillsboro Oregon
    Whats a \"Gov-Loc\" *stupid question*
    The guy at 4wheel parts said "A 14bolt with a gov-loc is a ticking time bomb" is a gov-loc just a locker that engages when you stomp the gas? or is it an actual name of a brand or what? Thx for feedback
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Re: Whats a \"Gov-Loc\" *stupid question*
    A "gov-loc" is actually a locker made for GM for the military by Eaton. GM uses it also on the trucks it pruduces. It uses centrifugal force to gauge how much "lock" it engages to the clutches. In other words it's an open-diff, posi, and locker all rolled into one. However, when it goes into full lock, you have to be spinning the tires pretty hard, and it engages suddenly, which can make them explode. They're OK for light wheeling, but I wouldn't use one for anything else. They're one of the weakest carriers used in an axle.
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  3. 84silverK5
    Nov 28, 2001
    65
    Hillsboro Oregon
    so the guy at 4wpw was right kinda surprising, it sounds like i could be cool, but if its weak..... thx
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    the 14 bolt gov-locs are stronger than the 1/2 ton counterparts. then again anything 14bolt is that much stronger than the 1/2 tons stuff
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    It's all fun and games till someone loses an eye!
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Mine in my '85 K30 is working just fine. Probably working too good, too. I can turn corners and the tires are chirping on one side, trying to grab traction.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  6. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    When I was reading up on Lock-Right diffs I ran across some stuff on Gov-Locs. The stuff I read said the 3/4 &amp; 1 ton ones are "ok", and the 1/2 ton ones are "time bombs". This is where I read it, has a picture and discription too: http://www.ring-pinion.com/gear/g0599.html
    Never said I could spell!
    '70 K-20 San Diego, CA
  7. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Clicky:
    <a target="_blank" href=http://www.ring-pinion.com/gear/g0599.html>http://www.ring-pinion.com/gear/g0599.html</a>
    I'm too lazy to stick shift,that's why I prefer autotranny.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Not real sure about the comment that the Gov-Lock was made for GM, for the military??? The CUCV K5's w/ the 10-bolt rear axle had the Gov-lock, but the pickups with the 14 bolt FF had a Detroit locker.
  9. dyeager535
    26,975
  10. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    I read about it in an off-road magazine. Can't exactly remember which one.
  11. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Sorry, the "gov" does not stand for "government", rather it stands for governor. The principal is that it uses a governor type design that allows the the differential to lock.
