Whats all involved to convert to ford D60 high steer
Discussion in 'The Garage' started by Z3PR, Jul 5, 2004.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    O2bJimmy called sence he isn't a member. Came acrost a ford cheap. Asked if it'd worth it cost wise.
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Worth it for what? Whats it going to go in? If its a good price id snag it. crossover/histeer will work, same for chevy/ford.
  3. o2bjimmy
    o2bjimmy 1/2 ton status
    Jun 19, 2003
    307
    Rapid City, SD
    Its a high pinion d60 front and a 60 rear both with 4.56 gears, good breaks and not 1 leak. I was just wondering what is involved in putting it in the blazer. The axles are costing me 500$ /forums/images/graemlins/yikes.gif I also would get the rest of the Furd along with the axles. So would it be cheaper too swap them into my blazer or sell them and try to find a gm 60 /forums/images/graemlins/confused.gif
  4. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well thats one hell of a deal! /forums/images/graemlins/thumb.gif
    Depends what year it is. 77-79 fords were the only ones with 32" spring center, all the rest were 36". Since there both already geared you could swap in a driver drop 205 and run the axles.
    Or what everyone else is going to say is, since the ford 60 is on the drivers side, guess your best bet would be to sell it and get a GM60.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Don't run hysteer on a Ford D60 HP. You will most likely break the knuckles. A local AZ guy broke 3 Ford knuckles, and I don't think he was even running hysteer. He now runs Dedenbears to cure the problem.
    Ford knuckles are even weaker then the Chevy knuckles, and running hysteer on Chevy knuckles is a gamble.
    Harley
  6. o2bjimmy
    Jun 19, 2003
    307
    Rapid City, SD
    Its a 79. but since i get the rest of the truck its got the transfer case.
  7. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Right on, then bolt it all up! Even if you upgrade the knuckles later, your still ahead!
