whats behind the panel?
Discussion in 'The Garage' started by lunchbox, Nov 19, 2006.
  1. lunchbox
    lunchbox 1/2 ton status
    Jan 22, 2006
    309
    novato,california
    im planning on putting in some 6.5 inch speakers in the jimmy tommorow and after many different faild ideas im gonna go with mounting them in the door, ive got power windows will that be a problem, ive looked at pictures and it looks like some have put them right below the window switch and door lock switch parallel with the padded arm rest, is this a good idea?:dunno:
  2. goldwing2000
    goldwing2000 Guest
    Best advice: take the panel off and see for yourself. It's only a few screws.
  3. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    If you have power windows it probably wont work unless your speakers are really shallow. Also if you do check it make sure that you roll the window up and down first.
  4. ChickenRammit
    ChickenRammit 1/2 ton status GMOTM Winner
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    i had that problrm too, they have some spacers you can buy at any stereo shop that shim the speakers out and then there is no contact between window and speakers. you can also just make the spacers out of plywood or particle board. you just trace the shape of the speaker onto the wood and cut it out with a jigsaw.
  5. lunchbox
    Jan 22, 2006
    309
    novato,california
    ya i tookl the panels off before and i guess my question was is it possible? sorry, but after tinkering today i think im just gonna fiberglass an enclosure under the seats.:waytogo:
