What's best donor for a 5 speed?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Jul 4, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    What\'s best donor for a 5 speed?
    What would be the best donor vehicle to look for that would have everything I need for a 5 speed swap into my 87? It currently has a 700 auto and 208 case. Also, what about a 205 case to put behind it?
    Big K<P ID="edit"><FONT SIZE=-1>Edited by bigk on 07/04/01 12:44 PM (server time).</FONT></P>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: What\'s best donor for a 5 speed?
    What you want is a NV4500. The problem is that most of them are gone before you can get to them. They came out of late modle GM and Dodge HD trucks.
    '71 Blazer CST with alot of rust
  3. bigredblazer
    bigredblazer 1/2 ton status
    May 10, 2001
    170
    western slope
    I forget the reason why, but you don't want the chevy nv4500. Get the Dodge version, but be careful looking on junked Dodges some of them have a Getrag 5 speed. DO NOT buy this transmission. Advanced Adapters will have everything you need to put it behind your engine, and mount a 205 behind it! Good Luck......Jon
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Chevy doesn't have as good of a 1st gear I don't think.
    But I don't think the Dodge has a synchronized reverse either.
    Tim
  5. 454Blazer
    454Blazer Registered Member
    Nov 1, 2000
    23
    Albuquerque, New Mexico, USA
    I have a chevy NV4500, it has a 6.34 non sychro first. The Dodge is 5.34 (or close). You would never use first in either tranny on the road anyway so either is fine. The chevy is sightly lower. both are incredible versions. Advanced Adapters likes to put down the chevy version because they can't get them anymore, only early chevy 4500's had the lower first gear. (the opinions stated above may or may not coincide reality) :)
    <A target="_blank" HREF=http://members.home.net/snarrlman/index.html>http://members.home.net/snarrlman/index.html</A>
