Whats Best Upgrade From Corporate 10 Bolt??
Discussion in 'The Garage' started by 1985K20, Feb 22, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Just wandering what's the best bolt on upgrade from a gm corporate 10 bolt for the front diff?? (my truck's a 85 3/4 ton, got a 14 bolt ff at rear):confused:
    Or is a 10 bolt good enough to handle 35'S??
    ***i dont drive her to hard neither***
  2. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    Just want to add this:3.21 final ratio
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run a 10 bolt front with 35's. As long as you are not a throttle jokey it will be fine. As for best upgrade there are lots of different options depending on what you do with the truck.
    The upgrades I have done with my 10 bolt front are beefy tierod, beefy diff cover, locker, gears, crossover steering, and a little shave work. All of this stuff may not be necessary depending on what you want to do with your truck.
    Harley
  4. mightywhitey_k5
    mightywhitey_k5 Registered Member
    Sep 3, 2004
    74
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your 10 bolt will hold up to 35s just fine.
    If your gears suck, re-gear.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    He is talking about his front 10 bolt axle, not a rear. He already said he has a 14b out back. There is no 14bff front axle (except custom hybrids).
    Harley
  7. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    Thanks for the replies guys, i'll probably keep the 10 bolt...and eventually regear to 3.42's or 3.73's.I just wanted to make sure that a 10 bolt was 35's friendly
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    35" tires will be ok on a 10 bolt front. 35" tires will make it possible to break things though, so keep that in mind. Good maintanence is the key to longevity.
    Harley
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah, for 35s your fine. Personally I wouldnt spend the $ to regear a 10 bolt tho... you could easily find someone with the new gear you want selling their axle dirt cheap as they upgrade to a D60...
    j
  10. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    This neccesarily doesn't costitute an axle upgrade but if you want to add some strength up front for your steering box, get a steering box brace. With 35's it will definetly be needed. I have a Dana 44 (pretty much a 10 bolt) with all the goodies; chromolys, ctm, arb, crossover steering, diff gaurd, heavy duty tie rod. I got the whole axle with all of the above mentioned for $400. Other wise I wouldn't have been able to afford all those goodies. But if you can they make it pretty nice for 35's.:)
  11. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    To run 35's, I'd go with at LEAST 4.10 gearing. Just my opinion.
  12. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    If you re-gear and run 35's, I would go 4:56's. I have those gears in my 1990 K5 and I hardly use the overdrive from the 700R4, meaning a good TH350 or TH400 with those gears/tires would suit me fine. What transfer case you running?
  13. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I also have a 1990 K5 with 4.56 gears. I think they're perfect. I would not want to run a TH400 or like the original poster has...a TH350 with 4.56's though. I use overdrive all the time (highway driving) :thinking:
  14. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    i run 208 tc, and the tranny is a th350...that's why i was not gonna numericly too high with the ratio...i guess 3.73's or 4.10's would be fine, would'nt it???
  15. rerun93
    rerun93 Registered Member
    Dec 3, 2004
    98
    chico, ca
    i have 4.56 gears and a th350 and i like them. freeway kinda sucks cause anyfaster than 60 for me and i can watch my gas gauge drop real fast. but iam never on the highway so there perfect for me
  16. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    I have 36s and 4.10 gears without overdrive, I think it works fine on and offroad. I would go with 4.10s again.
