Whats better Performer or Performer RPM?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ditchdigger, Mar 19, 2001.
  1. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    Is the Edelbrock Performer or the Performer RPM better for a 4WD I'm thinking the performer for (Idle to 5500RPM)supposedly low end torque versus the higher RPM Performer RPM
    What you guys think, seems like the RPMs series have a more aggressive intake pattern but is that for all high end torque
    If it ain't Intimidating / It ain't a Chevy !
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    If your doing off-roading you want lower end torque...
    Um... yes officer I know it's too big...
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I'm thinking the Performer one because a Blazer spends alot more time under the 1,500 than a sports car. According to Edelbrock the performer has a "dual plane manifold that boosts power from off-idle to 5,500 RPM" The RPM "are hig-rise dual-planes to give you power in the 1,500-6,5000 rpm range" What that means, I dunno, but thats what they say.
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    i use rpm. realisticly how often are you under 1500?i like havin the xtra top end there when needed.but im into boggin rock crawlers may see it different.i think a mag did a test on these 2 int and a single plane the rpm lost nothing on the bottom and really shined at the top.close to single plane.best of both worlds.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.
  5. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    When you're barely luggin down the trail you're at near idle speeds. Not many of use exceed 5,500, but then again some do. I guess I was thinking more in terms of my own usage to be honest. I'm pretty much a city boy that does a little fishing. I don't spend too much time over 1,500 because I'm running those damn 3.08's along with my 31's. This weekend, if all goes well....in goes new axle #1, an open carrier, 3.73, 12-bolt! Then when I get another 3 or 4 day weekend, in will go axle #2, a Dana 3.73 front [​IMG]
  6. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    well,my motor should idle around 1200-1500 so idle is a variable baseline.really not gonna be too good luggin around trails.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.<P ID="edit"><FONT SIZE=-1>Edited by pureinsanity on 03/19/01 08:04 PM (server time).</FONT></P>
  7. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Holy Crap! Sounds like you got a hot rod on your hands, lol. Gotta see some pics. I just have stuff that makes me look fast. Ya know, finned alumminum Edelbrock valve covers, MSD wires, lol.
  8. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    The performer is what you want to go with.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  9. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    Hey Ditchdigger! Thanks for the email on your Trans Am. I just put in a Performer and Edelbrock RV cam PN 2102 (and the double roller timing chain)--it made an obvious difference. My friend slapped a Performer on without switching the cam and it made no difference. The RPM is for street/hot rods. If you wheel: Performer. If you race: RPM. Edelbrock doesn't have very many cams to choose from and they lead you to believe that other cams aren't as "dyno matched." That's got some hype to it--you could call Crane Cams and open up more options.
  10. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    blazerboy,ya things got a little outta hand.hehehe!ill be droppin pics as soon as theyre developed ive taken pics the whole way.
    PURE INSANITY
  11. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Ditchdigger, I myself would go with the Performer, even and Weiand Action plus #8004 non egr or #8000 egr all of these will work well in a blazer that is if depending on how you 4wheel your ride, have you put a cam in yet? As you know all that stuff works togther, A call to your locale speed shop will help out to. Oh you live in North Dakota good luck j/k Eric
    Lost? i'm not lost i'm just disorienated
