Whats better: swap 10bolt w/ disc from 88k5 or add discs from 71 onto D44
Discussion in 'The Garage' started by mcmlxix, Jun 30, 2003.
  1. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
    I have a 70K5 with D44 front with manual drums all the way around. I want to add disc brakes. I have a 88k5 that has a 10 bolt with discs. Whats better? Is the D44 stronger? One has 28 spline and the other has 30 spline.(I think) I have a 71 with Disc Brakes that I have all the parts to swap over? I dont have any plans for off road torture but I dont want to downgrade the strength of the axels either? I searched and found conflicting info on swaping drum to disc on the D44.
    See two pics in my member gallery.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Well since no one else is chiming in, I will..
    The 70K5 44 will have the smaller u-joint than the 88 10 bolt. So you'll have some increased strength there. The 10 bolt does have smaller carrier bearings, but not by much.(not enough to make a huge difference)... The 44 will also have smaller wheel bearings...
    The 88 10 bolt should be a 30 spline unit unless it is an early 88 axle before they went to 30 spliners.
    One last thing I can think of is overall width. The 70 k5's were alittle narrower I thought. Check the overall measurements, spring perch widths etc.. If it were me and the ratios were the same as well as the widths springs perches, etc... I would go with the 10bolt......
