whats goin on here?
Discussion in 'The Garage' started by eightyone, May 4, 2004.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    well, i was planning on swaping out my automatic tranny from my 71 blazer wich i thought had a 305 in it...i bought a hydro clutch from a 85 suburban, and i have an sm465 out of my old 81 blazer with a 350, the problem is here...i went to put the flywheel/flex plate (not sure what its called for manuel tranny) onto the motor, and it is way to big /forums/images/graemlins/dunno.gif does anyone know what this motor could be? i was under the impresion that 305's were pretty similar to 350's? /forums/images/graemlins/1zhelp.gif any help would be apreciated since this project is on hold. /forums/images/graemlins/frown.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    is the motor a 1 peice main seal? in 86 they went to a 1 peice rear main seal, and the flywheel is different. also the 1 piece motors have a externally ballanced engine, is there a wieght on the old flywheel?
  3. eightyone
    Apr 25, 2004
    292
    long island
    there was a weight on the old flywheel, does this mean the mtor is newwer than 86? and could i just get a new flywheel and reuse my old clutch, thanks for the info. /forums/images/graemlins/1zhelp.gif
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it probably is, can you see the seal with the flywheel off? if so then you have the wrong flywheel.
    yes if you can find a flywheel from a 86 or newer truck, the pressure plate should bolt up. /forums/images/graemlins/waytogo.gif
  5. eightyone
    Apr 25, 2004
    292
    long island
    thank you so much for that info, i was gettin worried id need to buy a new clutch, or even worse, the motor was gunna be useless with the tranny i had, thanks again for sharing your knowledge...back tot he junk yard... /forums/images/graemlins/thumb.gif
  6. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    Why don't you post up the casting number and we can figure out exactly what it is for you. The casting number is on the bellhouseing flange on back of the motor top driver side. Also check the little pad that is sticking out behind the alternater where the head sits. If it hasn't been decked then there will be a vin stamped there and a 2 or 3 digit suffix code which will narrow it down further what it came out of. Post them up and will look in my little book or you can check www.mortec.com I think they have casting and suffix codes posted there. Then you can figure out exactly what you need.
