Whats involved in a TH400 to 700R4 swap.
Discussion in '1982-Present GM Diesel' started by AzzKicker, Jan 19, 2003.
  1. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    My TH400 is in good condition. The Highway is killing me though. I just cant take the noise. Anyway, heres my specs:
    6.2L / TH400 / NP208 with 4.10's.
    Is there a place I can order a rebuilt 700r4 to go into my diesel without the BS of swapping shafts, and getting adapters and all that crap. I just wanna REMOVE TH400 and INSERT 700R4. If I have to move crossmember back or forward thats no big deal. I dont want to have to modify much. Will I need longer driveshafts, shorter driveshafts ? if so, can I get them off another truck with a 6.2 and 700R4. ALSO were 700R4's ever factory Trannys on a 6.2 and if so, what trucks were they mostly found on.
    I want this as simple as possible.
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    My K5 came with one, ill trade you!
  3. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    how will mounting be? what would I need. My truck is prolly longer than the K5, so is there any differences in mounting, etc?
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You will need the 700 and the 208 together.
    All light duty 3/4ton and all half ton diesels came with the 700/208 combo.
    I am sure a lot would like to trade with you, which I think might make you change your mind.
    The only bad thing about the th400 is the RPM's, the only thing good about the 700 is the RPM's
    /forums/images/graemlins/thumb.gif
    If you want I will trade ya the whole assembly.
    The tranny was rebuilt and then the engine started to act up so I parked it.
    /forums/images/graemlins/deal.gif
    You still need to figure out the driveshaft length.
  5. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    Will bigger tires let me go faster with less RPM's.
    Say at 55mph its turning fast RPMS. If i went to say 35's, will the engine be less noisy at the same 55mph
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I was going to suggest that.
    I did that myself, I have 35" tires on 308 gears, I don't have to worry about trannies since it's the sm465 /forums/images/graemlins/thumb.gif
    The diesel still pulls it no problem, I am even thinking of going 38 now.
  7. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Keep what you have and go with bigger tires. I have 35s with 3.73s and dont put in overdrive unless im going 65, 70. What size tires do you have?
  8. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    /forums/images/graemlins/frown.gif 265x75x16. /forums/images/graemlins/frown.gif I need like 35's or 33's
