What's involved in my 85' K5's upcoming 3in body lift install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudhucker, Aug 6, 2002.
  1. Mudhucker
    Mudhucker Registered Member
    Jul 31, 2002
    9
    Kamloops B.C. Canada
    What\'s involved in my 85\' K5\'s upcoming 3in body lift install
    I'm very new here so if this has been asked a million times could someone point me in the direction of the past posts rather than waste bandwidth, thanks /forums/images/icons/smile.gif I would like to know what i have to do other than jack up the truck, slide in the new bolts and blocks, lower the rad and drive away?? Do i have to torch out holes to access bolts? extend shift linkages as i have a 700r4 tranny? what's the best way to extend my filler hose? Help would be much appreciated thanks /forums/images/icons/smile.gif
  2. Mudhucker
    Jul 31, 2002
    9
    Re: What\'s involved in my 85\' K5\'s upcoming 3in body lift install
    nobody has done a 3in body lift?? or read a previous post on here?? /forums/images/icons/confused.gif
  3. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    i dont believe you have to torch no new holes. i am having to extend my shift linkage on my th-350, dont know about your 700, but id say prolly.i did not have to extend my filler hose either. basicly you have to be careful when jacking it up making sure everything is disconnected that can get damaged and stuff is out of the way. watch any electrical wiring. this is at best and safest a two man job.good luck, hopefully someone else chemes in here.
  4. Mudhucker
    Jul 31, 2002
    9
    sounds kind of easy?? what about my steering column, does it have to be lengthened??
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    i did mine in 3 hours today
    and body mounts too.. they were 80 bucks do them too!!!!!
  6. reddog64
    Nov 9, 2000
    3,325
    no your colum will be fine
    just be carefull...
    always always put wood blocks between frame and body while reachinbg underneath your truck to do this!!! /forums/images/icons/shocked.gif
  7. Mudhucker
    Jul 31, 2002
    9
    what problems did you run into and what could be or become a problem?? Truck looks good, love camo paint schemes /forums/images/icons/laugh.gif /forums/images/icons/grin.gif
  8. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    You'll need to extend shifter linkage and remove bottom portion of your fan shroud. Steering column will be OK and your gas filler should be OK. You may need to notch out your floor for your t-case shifter.
  9. big d
    Oct 24, 2001
    1,236
    illinois
    im thinking no, but all the info should be in the instructions. to be honest with you i had to replace my column the same time i did my body lift. you may want another opinion on this one.
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You wanna help me with mine this weekend, only doing a 2" with new body mounts /forums/images/icons/grin.gif
  11. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    try a search
  12. Mudhucker
    Jul 31, 2002
    9
    cool thanks guys, how do i extend my shift linkage??
