whats involved in this swap?
Discussion in 'The Garage' started by vw62rag, Jan 22, 2005.
  1. vw62rag
    vw62rag Registered Member
    Jan 1, 2004
    78
    topeka, KS
    hello, i have a full size jimmy with a 350, 700r4 and a 208tc, id like to ditch the 700r4 before it gernades. i have a good th400 out of my old 3/4ton 2wd suburban jus sitting here and id like to put that in insted. what all is invovled? what other parts will i need?
    thanks in advance for help!!
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you need an adapter for the TH400, new output shaft, and all the work to put the two on.
  3. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    so jus 2 parts? were can i find these parts? i dont mind the work. i jus really want the 700r4 out
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    sorry I wasn't clearer, yes 2 parts but they happen to be 2 expensive parts. Not to mention that installing the output shaft requires complete disassembly of the transmission. It is a good deal of work.
  6. vw62rag
    Jan 1, 2004
    78
    topeka, KS
    wow! compete dissasembly of the trans? i dont think im gona be able to do that. what do you all recamend doing? having a shop do it?
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    that or if you can locate a 4x4 trans just get that.
  8. diesel4me
    Jul 24, 2003
    17,539
    923
    Massachussetts
    or get a divorce
    You could install a divorced transfer case and use the 2wd tranny,but thats as much or more work than gutting the TH400 to put the 4x4 output shaft in the 2wd tranny....you'd need a divorced T case,lenthen/shorten the driveshafts,shifter linkage,etc--probably easier to just but a TH400 4x4 tranny,with a NP208 that mates to it(A TH350 or 700R4 case has different input spline sizes--wont bolt up,but you could make it work,you still need a TH400 style case for the parts to make it work,might as well put the whole case in)..
    The beauty of a divorced transfer case is you can use ANY tranny in front of it,manual or automatic,2wd style,simply by using the appropriate short driveshaft between the tranny and transfer case--but its kinda involved getting such a t-case installed,mounted,and hooked up to a shifter...This is why I liked the old GM trucks with the rockwell case,it allowed a lot of tranny conversion options,and 2wd or car trannys are cheaper and more plentiful...:crazy:
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you would be best off finding a th350 4x4 trans, they are dime a dozen, and pretty much bolt right in palce if you show it where ot go
