Whats involved? SFA swap on 2wd 1/2 ton 89 Chevy
Discussion in 'The Garage' started by Russell, May 30, 2006.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Hey guys!
    The farm is in dire need of a new truck for beating around in the fields. They are using a gorgeous, low mileage 2000 Special Edition GMC Sierra at the moment, which is just wrong!
    So, I've got an 89 Chevy half ton with literally half a million kilometers on the clock. It is in dire need of a front suspension job, and is pretty loose on the road. The rest of the truck is in relatively excellent shape though, and being an extended cab longbox, it is perfectly suited for the farm.
    I'm tempted to buy a 1/2 ton 10 bolt front diff + all the brackets for the front and rear of the truck, and convert it to 4x4. I'd change the front diff to 8 lug outers, put a 14 bolt out back, and put some 3/4 ton, or if I can find a set, 1 ton springs on it front and rear, and convert it over. In it's half ton 2wd form, it'd be totally useless out there.
    I wouldn't want more than a 4" lift or so, just enough to pack some 32 - 33" mud terrain tires onto it and not get a bunch of rubbing while it is flexed out on some of the hills out there.
    I'd then use the divorced 205 transfercase I have to get the front and rear shafts the same length, and either stick with the TH350, or possibly convert to an SM465 for the transmission.
    Now, while I would have no problems doing the SM465 swap, installing the 205, or getting driveshafts made, I'd need to know what all a guy has to do to get that front diff installed. I assume I'd need cross over steering for it, and of course I'd have to bolt the spring stuff on, and possibly move the spring perches, but what else would I need to be concerned with?
    I'm hoping to spend relatively little on this truck, and if it will cost more than 1500 to build, I'd rather just try and sell it as is for that price.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Go to the IFS forum farther down the page, there is post on this verything.
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    ya we got lots in there on this.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Yup, follow the link im my sig...sweetk30 did one too and some one else did ..li just cant remember the username...
  5. Russell
    Jun 23, 2000
    7,921
    331
    Well, I did a bunch of reading and I've come to the conclusion that the truck would simply sit up way too high to be useful... Good for running big mudders. If it wasn't for that crossmember hanging so low and causing clearance issues with the diff, I think I'd go for it, but yeah, an 8 foot truck isn't good for anything but wheeling, LOL
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    If the crossmember was cut and plated it would work fine... That and run a set of 2" front 73-87 springs. Would give ya 4" or less of lift. Youd have to modify the brackets like i did in my build up to get even a decent shackle anglebut its not to hard to do.
  7. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    551
    Wasilla AK,
    Put a Snow plow on it that'll suck that frontend down!!!
