whats latest year of wheels that will fit 8lug 4x4 87-older ?
Discussion in 'The Garage' started by R72K5, Nov 18, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    will any or all 88-up 8lug wheels fit 87-older 8lug ?
    matter if 2wd or 4x4 ?
    if not then why and what years still will interchange ?
    i want to keep my eyes/ears out for some nice 16" wheels for the K20 to replace the stock painted 16" with , but got to know what years will fit and what wont
    thanks
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    All chevy, dodge, and ford 8 luggers are the same except the new superduties as far as I know. It is 8x6.5
  3. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Furd got cheap.. they (Superduty) only are 7 lug wheels.Glad the others didn't follow the "blue oval"!
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    The newer wheels are backspaced differently and will sit snug with your tie rod ends but should usually fit ok.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah but some yearsof dodge or ford had differetn size bearing hole other than the 4.5" that was used 90%of the time
    so ford went to 7 lug ?
    odd...
    thanks
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    No, the superduty's are still 8 lug...it's just they're on a 170mm bolt circle, not the common 6.5"
    Bolt patterns will be the same on all 8 lug wheels excluding the '99-up superduty's. You have to watch out for backspacing though (the newer chevy's have a larger backspacing, I believe, so you might have clearance probs with the tie-rod ends). And, like you mentioned, some wheels have a different size center hole. I'll let someone else give you the facts on that because I'll probably turn 'em around. /forums/images/graemlins/smirk.gif /forums/images/graemlins/thumb.gif
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    umm unless the superduty in my driveway had a lug added when I wasn't looking its 8 /forums/images/graemlins/wink.gif. 99+ super duties are 8 on 170mm as far as I remember. I know where this thought comes from and its really weird but common, in 96 or 97 Ford built the first F150s on the newere body style, then they brought the F250s to the same body style, and all the F250s produced on the IFS body like that have hub caps that only have 7 bumps that are suppossed to show the lugs underneath. If you pop the cap there are 8 lugs I guess they started making the caps and realized they made the bumps too big and just said go with it.
  8. heavy4x4
    Aug 28, 2002
    3,270
    Taken from a reply made by "mosesburb":
    GM uses the smallest center hole. GM trucks can use Ford and Dodge wheels, but Fords and Dodges typically can't use GM wheels. There are exceptions to all rules, but, for the most, part this is usually what you will find.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got a set of 16-inch factory rally type wheels from a 1989 3/4-ton 4WD pickup. They have stainless trim rings and chrome center caps. $100 + shipping and they could be on your doorstep. /forums/images/graemlins/cool.gif I can even bolt one up on the front of my '90 'burb for ya to make sure that they don't hit anything. /forums/images/graemlins/thumb.gif
  10. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    ford uses 7 lugs on f150 HD (7700 series) and LD f250(non SD)...3/4t and 1t super duties are all 8 lug...
  11. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    I put 2003 Silverado 2500 HD 4x4 wheels on my 2wd '71 burb. I had no problems with backspace, just needed some conversion lug nuts to run the center caps.
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Nice first gen! Thats a cruiser there! /forums/images/graemlins/thumb.gif
  13. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Just put a set of 16" x 6" stock steel rims from an 89 3/4 to GM on my 87 GM. Fit fine. Hubcaps won't fit. The 89 use a ring and center piece. Or, just pick up a cheap 1 piece hubcap like I did and cover the whole thing.
    Eric M.
  14. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    drool!
    i like very much, i miss my 68 panel delivery now, should have kept it, damn.
    i saw a 68 burb all restored and 100% perfect running around town last week passing out flyers using the truck, it was all nice and bright white and drooool.,,,,,,
    i dont know where it was from but has IL plates on it now, and must have been alot spent on restoration or it came from a better region
    anyways it sounds like that wheels 8 lug will fit all way up to current ones, hmmm... cool /forums/images/graemlins/laugh.gif
    thanks
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I didn't think they sold LD F250s anymore and I'm pretty sure your wrong, I've never removed the hubcap myself but I know some people who have one on a farm and they say its just a 7 lug hub cap there are 8 lugs under there.
  16. Grim-Reaper
    7,385
    Atlanta
    I'm trying to find a set of those rims to put on my 88 Burb. Missed a set a few months back that were take off's with about 100 miles on them tops.
  17. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    The F-250 LDs, or F150 7700 later on, did in fact have 7-lug wheels.....stupid move IMHO. Theses trucks look just like the '97-up F150s w/ the heavier suspension & 7-luggers.
    The Super Duty's have all been 8-lug up to the larger 10-lug HEAVY trucks.
    Doc
  18. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    hmm interesting, never bothered to pop the cap was just told by people with access to one it was 8 lug, though knowing those guys they saw some old like 77 ford with newer caps or something, or just made it up cause they had no real clue.
  19. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    Light duty F-250's (96 to present) have 7 lug wheels acording to my buddie that's into fords he said they can't find rims other than stock cuz they have the odd bolt pattern (kinda like the small 6 lug wheels on dakotas )
  20. yellowK20
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    Where did you get those lug nuts I have a set of those caps and I want to run them on my 88 burb /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
