WHATS MY TRUCK GOING TO RUN IN THE 1/4 MILE??
Discussion in 'The Garage' started by 89K1500Chevy, Feb 18, 2004.
  1. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    OK so on sat me and some friends are going to silver dollar for test n tune runs. Im NOT taking the 4x4 it runs a 17.89 sec qrt mile /forums/images/graemlins/rotfl.gif but that is with the 33's on it. Im running my 84 GMC 2wd street beast. Heres the specs ZZ4 HO 350 w/ old school valve cover adapter plates / 355hp 405 tq/ 750 hi po quadrajet coated headers w/ duals H piped hi flow cats and flowmasters/ TH350 tranny w/ shift kit and stock Torque converter(Yes it needs a Stall) and the rear is a 10 bolt with 3.08 gear and open..(yes needs bigger axle with 3.55 and posi) Ok so far i know it can hit 50-55 in first gear/ and 2nd is down at the choke light so i should be able to do this run in 2nd im going to let it shift auto a few runs then manuel and see what it does. So with it having probs hooking up what do yall think Im going to Run? And im having probs with it bogging down at take off then breaking loose when it picks up rpms at around 30-40 mph then at the 2nd shift also.
    try to get pics of us out there.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    1/4 mile? I would guess 14's. 3.55's with a LSD would help A LOT!!! Maybe some wider tires to put more rubber to the ground.
    Kris
  4. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    I'm with Tim, 15's. That is a heavy truck and it(no affence)is not set up very well currently. Better suspension, different rearend with what you said, different TC, better tires, and shed a LOT of weight somehow from that truck and it might get down into the 12's. /forums/images/graemlins/thinking.gif
  5. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    14's would surprise me. I'm with Tim...high 15's, low 16's maybe.
    Even a C10 ain't light, it has crap gears, no posi, poor weight bias, a 'bog', and the aerodynamic's of a farm building.
    Rene
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    and the fact that pickups with horsepower are hard to make hook up. The fact that the main weight is over the front end, and the suspension isn't designed for it.
  7. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Low 15's . Try power braking of the line. You'd be surprised how much that may help. /forums/images/graemlins/waytogo.gif
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    not as much power braking, some guys call it stalling up, hold on the brake and gas a little to bring RPMs up and build some power right off the line, creates a traction issue though.
  9. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i say high 15's best, probly low 16's. but if you got it dialed in you should be getting low 15's, maybe even break 14 with the right gears and converter.
  10. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    15 ish would be my guess, let us know what it does. /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif
  11. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Take off the bed and front clip and put some weight over the rear axle
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah I was gonna say 16s but maybe that's pushing it.
    Depending how messed up the carb is, it could make you even slower.
    No posi and no traction isn't going to help either.
    Be lucky to break 15.99.
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    bogging down then getting hit with power sounds like an accelerator pump or just a need for a good carb /forums/images/graemlins/rotfl.gif I used to have that problem with a QJet, I found the solution, an Edelbrock Thunder AVS carb.
  14. tRustyK5
    Jul 23, 2000
    36,172
    1,381
    E-town baby!
    I had an 88 C1500 short box, 3.42's, gov-lock (not too bad in a 2WD) 275/60R15's on the rear...it had a fairly stock TBI 350 and a 5 speed. That had major traction problems, and would easily smoke em for 20 or more feet hitting 3 rd gear. Best ET was mid 16's, with no 'bog', better gearing and a traction aid.
    This truck has more hp and torque, but worse gears and stuff.
    Rene
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A stock TBI 350 is only 215 HP though.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    like I said, pickups aren't designed to be dragsters, look at s10s, to effectively get one to hook takes a four link setup and front suspension that will help weight transfer. Plus the simple problem of axle wrap.
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i got mine with a similar setup (except engine) to run 15.02@86mph, you're making way more power than i was, so i'd say low 15s arent totally out of the question.
  18. 89K1500Chevy
    Nov 9, 2002
    645
    The bog isnt always very bad it depends on how she feels but im hoping its going to be low 15's mabey high 14's my buddy's honda is hitting 15.5's and i can take him easy but hook up at the track is going to be a prob. What i have planned to do is build the ZZ430 outta it 385 fastburn heads/ Hot cam/ 1.6 rockers= 430hp /430tq all for around 1500
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'd worry about traction and other things before more power.
  20. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I'm going to say high 15s/low 16s only because of your gears and lack of a posi. I'm gonna guess that you are going to have one hell of a time getting anything better than a 2.30 sixty foot at the best. Traction at SDR will most likely be a bit "off" due to the off season but at least you will have cool temps on your side.
    Have fun. I'm going down there March the 28th for a F-Body meet. Jipp by if you have the time. We rent the track and generally have alot of track time at the meet. You could basically make at least 25 runs if you wanted to.
    If you go, say hello. I'll be in a black 2000 Firehawk hitting a pretty mean lick or a grey 1985 LX Mustang Cpe.
