what's needed? 700r4 to 350
Discussion in 'The Garage' started by hawglet, Dec 14, 2004.
  1. hawglet
    hawglet 1/2 ton status
    Aug 4, 2000
    265
    Hastings,NE
    I'm going from a 700R4 to a TH350 in my 84. It has a 208 x-case. The 350 has the correct shaft to adapt to the 208. I know I will need a different torque converter and flywheel, but what else??? Are the mount bushings different?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will need a different converter, but should not need a new flexplate (flywheels are for manuals). it should bolt to the same holes. the mounts are all the same, you will need the correct dipstick. cooler lines should be the same.
    can't think of anything else.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I did this swap last year. I already had the torque converter, but yes you will need that. My TH350 i bought was from a 350/208 combo, but I don't think all TH350's have the correct output shaft. I think you need a longer one to get good spline engagement. You will also need the 350/208 adaptor. The tranny mounts are different and so is the crossmember. PM me if ya need any more info.:waytogo:
  4. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    differant kickdown cable too
