Whats needed for a 6" lift??
Discussion in 'The Garage' started by kdk82, Jan 26, 2004.
  1. kdk82
    kdk82 Newbie
    Jan 25, 2004
    Whats needed for a 6\" lift??
    Hey everyone! i've got a 2.5" lift on my k5 blazer and i'm gonna step up to a 6" lift. What am i gonna need? I'm going to put 6" blocks in the back and have my front springs changed out to 6" of lift. I know i need a dropped steering arm. What about driveshafts? My rear driveshaft seems short, but my rear axle hasnt been tilted at all yet. Can i lower my transfer case to get away with not having to get new driveshafts?
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Re: Whats needed for a 6\" lift??
    You should get new shafts made. Your stock ones will vibrate and be weak from being pulled all the way out.
    If you lower the t-case member make sure you use a kit and not the stock spacers because they can crack the frame.
  3. kdk82
    kdk82 Newbie
    Jan 25, 2004
    I've been debating if i should go with a 4" lift and 35's, but i just worry if i get into a flexing situation it's gonna rub real bad. It's a daily driver that will be taken offroading, nothing like rubicon, but beach/mud driving and some hills for sure.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Longer brake lines, longer driveshafts, dropped e-brake cable hangers, longer shocks. 6" blocks are a bit scary, since you already have 2.5" of lift in the rear you might consider adding a 4" shackle flip to that as an alternative to blocks.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I agree with the 4" Shackle flip instead of blocks !!!!!
  6. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Your also gonna have to re-route the exhaust crossover to run a front d-shaft.
