What's normal temp for a 6.2?
Discussion in 'The Garage' started by dremu, Jan 23, 2007.
  1. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Just installed a temperature gauge, sender in the stock location in the block, driver's side, and she's running right about 200*, at least according to the gauge. Is that good, bad, ugly?
    -- A
  2. jdemaris
    jdemaris Registered Member
    Apr 10, 2001
    76
    Normal operating temp is around 190 F. Point is, you want it to stay there when you start working it.
  3. dremu
    Feb 27, 2000
    15,968
    461
    Yeah, she seemed to stay right there even at highway speeds and banging on it ... well, as much banging on a 6.2 with 3.08:1's as one can do :rolleyes:
    -- A
  4. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    hey dremu, what kind of temperature gauge did you use?
  5. dremu
    Feb 27, 2000
    15,968
    461
    http://www.partsamerica.com/ProductDetail.aspx?categorycode=3342D&mfrcode=EQU&mfrpartnumber=6242
    That one, I think. Cheap, simple.
    http://www.slosh.com/ck5/temp-gauge-1.JPG
    Sorry for the crappy pic, flash in the dark. Anyway, the CUCV has the idiot light dash, i.e. no gauges, but I am too cheap and lazy to change the thing out ... I'm "keeping it original", yeah, that's it. :rolleyes: But after toasting the motor in one of my other rigs, I wanted to keep an eye on this one, especially as I *fear* what replacing that 6.2 would cost... so this was cheap insurance.
    -- A
  6. protechk5
    Sep 26, 2004
    2,015
    VA
    yeha well i got cucv too, so where did put the sending until at? you said "sender in the stock location in the block, driver's side," so what was there before?
  7. krechj
    krechj Registered Member
    Nov 14, 2005
    33
    Murderapolis, mn
    my 6.2 runs at 190 consistantly so id say thats normal... on my 6.2 there was a plug with an indented square top in the temp sending guage hole. its on the drivers side top towards the front of the truck if that helps
  8. 85burb4x4
    85burb4x4 Registered Member
    Sep 14, 2005
    27
    Gold Bar, WA
    If I remember right, the thermostat available at parts stores is a 190* or a 195* thermostat. On the 2 diesels I have driven (still own and drive one), the factory gage usually cycles around 200* and both engines have provided a lot of trouble -free miles. Hope this helps.
  9. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    since my new thermostat, mine runs at 200* and no matter how hard i romp on it, never hotter. i like it running as hot as is safe for my fuel economy. :)
  10. dremu
    Feb 27, 2000
    15,968
    461
    A sender for the idiot light, I suspect.
    -- A
  11. dremu
    Feb 27, 2000
    15,968
    461
    Sounds like a pipe plug ... like somebody blocked the sender off. :doah:
    But cool, as it were, sounds like the old girl is doing okay so far. Thanks all!
    -- A
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Depends on what tempeture thermostat you have. Mine came stock with I believe a 195 one, and it's always stayed right around 195-200. I tried an 180 last summer and it always stayed around 175-185. This was all with a newer radiator, clutch fan, and water pump.
