What's on your floor pan? Carpet or Mat?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mkmiller, Jun 6, 2002.
  1. mkmiller
    mkmiller 1/2 ton status
    Oct 31, 2001
    306
    Magnolia, Arkansas
    What\'s on your floor pan? Carpet or Mat?
    Looking to buy the floor interior for the blazer and was needing to how many of you have used carpet and are happy with it. What would you use if you had your choice? Also where would you get the best(not cheapo) carpet from?
    Thanks,
    Matthew
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Re: What\'s on your floor pan? Carpet or Mat?
    Nothing but old paint and bare metal with some rust for bad luck too.
  3. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    Depends on what the truck is for. If your muddin' or crossing a river the obvious choice is mats or a liner. If it's a daily driver my preference is carpet.
    Chris M
  4. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    When I lived above Soda Springs we had 7' of snow on the ground then it rained 12" in 24 hrs. The carpet in my CJ7 got soaked cause the only place left for the water to go was in the road. The carpet was bolted down under the front seats so I coundn't just pull it out. I had a sheet of ice on the floor boards for a couple of weeks till I went to Sac on a dry day and took the top off to let it dry out. Since then I don't want carpet on a 4x4 trail rig. I want to get the padded MIP rubber mats LMC has now for mine. /forums/images/icons/wink.gif
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i think the smartest thing is to do a spray on bedliner.then you dont have to worry about rust from the interior.this is what i'll be doing eventially anyway.
  6. Racefreak
    Racefreak Registered Member
    Apr 1, 2002
    67
    San Antonio, TX
    RUST! I have some correct carpet brand new in the garage for a 69-72 if you need it. It is brand new, never installed. It came from LMC. It's the correct loop style, in Brown. Front, rear, & wheels wells. I am doing the Line X, as my K5 will be a beach rig.
  7. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Rhino liner
    John
  8. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I would prefer spray on bedliner but the paint-on liner seems to be holding up pretty well. The hump is just painted flat black.
  9. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Mine came with a mat, but I'm going to put carpet into it. It's too freakin' loud inside the thing without some insulation.
    Oh, I'm going to bed-line the floor before I put carpet into it (after I fix the rust holes).
  10. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Steve have you looked in the new LMC catalog at he MIP molded rubber mats with the pad? Just like carpet but you can wash the floors out with a hose. I think that may be the answer for a trail truck. They use something simular in big rigs trucks and it helps keep the noise and heat out with out the matience of carpet.
  11. mkmiller
    Oct 31, 2001
    306
    Magnolia, Arkansas
    I wish the carpet you had was black! I was thinking of bedlining the inside then carpeting it. What is the best thing for keeping the noise and heat out? Do you use that felt type pad like is in trucks?
    Matthew
  12. ryanNC
    ryanNC 1/2 ton status
    Dec 7, 2000
    182
    North Carolina, Valdese
    i've got some pics on webshots underneth i like it alot
