whats size centerpin for rear springs on 89 Jimmy?
Discussion in 'The Garage' started by hunter, Feb 8, 2005.
  1. hunter
    hunter Registered Member
    Oct 28, 2004
    52
    Houston,Texas
    I have an 89 GMC Jimmy 10 bolt rear, I need to add a 4deg shim on my rear springs to get the pinion angle correct and I will need new center pins.
    What size are they for the rear?
    Is it the same size for the front?
  2. hunter
    Oct 28, 2004
    52
    Houston,Texas
    Nevermind...did a search, looks like 5/16" :D
    what can I say...Im a newbie blubie :blush:
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    3/8 front and back on my truck. I'm running skyjacker front and tuff country rear springs. I don't remembe if stock springs are the same, but I think so.
  4. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Not to change the subject, but do the shims get bolted to the spring pack? I am putting shims on my Jimmy and i thought they just sat in there like a lift block would?
  5. hunter
    Oct 28, 2004
    52
    Houston,Texas
    http://coloradok5.com/forums/showthread.php?t=108575&highlight=centerpin+size
    Thats my problem, I keep getting mixed answers :confused:
  6. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I went throught this a couple of weeks ago. :confused: I uses some 3/8's grade 8 bolts and rounded the heads off so they would fit in the spring preches. the head of the bolt was 9/16 IIRC. I got them at OSH I think they were 4.5" or 4" long.
  7. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
