whats so bad about the ball style axles?
Discussion in 'The Garage' started by Seventy4Blazer, Oct 26, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i can get a ball axle(cant remember the correct name right now, its not a kingpin.)
    for CHEAP! its off a ferd, but i can also get one of 3 or 4 205's that will work for a doubler.
    so why are these axles not used as much? do they suck? are they spendy?
    ANY info helps. including the proper name.
    grant
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Are you taking about an eaton rear ... Maybe /forums/images/graemlins/thumb.gif
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Since you mention kingpins, I'm guessing your talking about the common ball joint style knuckles like a D44 or C10. IIRC, some (all?) of the Ford D60s have ball joint knuckles. I think the only problem with them is that they are considered weaker. But for the most part this shouldn't be an issue...
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm guessing that you're talking about a front axle that has a "ball" where we normally see the u-joint. It's called a closed-knuckle axle. They're good in mud since they're totally sealed. But they usually have pretty weak joints inside them. They don't use a standard u-joint. Various closed-knuckle axles have used different joint types over the years, most using some type of caged ball bearings to transfer the power between the inner and outer shafts. I don't think many of them came with disc brakes either as most manufacturers went to open-knuckle axles around the same time that they went to front disc brakes. /forums/images/graemlins/frown.gif
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah harry, you got it. thats the one. i thought there was another name for them. more "technical"
    but those are the ones i am talking about. i still have to jump up on the truck and make sure it is the right spring perch width an all. i cant tell the year of the ford. it is the right body style. if it is the right width and has disk(didnt pay that much attention) then i will pull the truck off the stack and pull the dang thing.
    thanks all for your help.
    Grant /forums/images/graemlins/thumb.gif
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oh yeah, since it's a Ford axle, the pumpkin is probably on the wrong side for our stuff. /forums/images/graemlins/frown.gif I've never paid much attention to the earlier ones, but in the 70's at least, they had the diff on the drivers side.
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, thta is no big deal. he has like 3 or 4 ford 205's that i can get. im not worried about that. i just need to go back tomorrow and see if it is disk brakes and the spring perches are right.
    Grant
  8. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Spring perches are going to be the same as GM but no Disc brakes till 75 or 76 for Ford. I am sure they went to open knuckle before discs. I dont think anyone ever made the closed knuckle axle with disc's.
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah, i looked at it today, DRUMS!!! /forums/images/graemlins/crazy.gif /forums/images/graemlins/frown.gif
    i guess on to look for another one i go.
    Grant
