Whats that noise???
Discussion in 'The Garage' started by blazen86, Dec 13, 2004.
  1. blazen86
    blazen86 Registered Member
    Sep 8, 2004
    55
    Virginia
    So for a while now, well actually since ive owned the truck, there has been a humming noise coming from sounds like the rearend at highway speeds when i let off the gas. I just replaced the U-joints, does that mean my rear end is about to take a turn for the worst.
  2. 84blazin
    84blazin 1/2 ton status
    Nov 9, 2004
    345
    Queen Creek AZ
    I have that too. Sounds like a semi's engine brake going off right?
  3. slyguy_22
    slyguy_22 1/2 ton status GMOTM Winner
    Dec 13, 2004
    789
    Lancaster, PA
    drain the fluid in ur rear and take a good look at it. metal water or other and i would sugg checking and and replacing the gasket
  4. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    I was having a weird noise too....then my rear diff started to leak...my pinion nut wasn't even snug! Replaced the pinion seal, snugged the nut(used lock-tite!) and is all better...
  5. blazen86
    Sep 8, 2004
    55
    Virginia
    Yep exactly kinda wierd I guess ill try to tear it down sometime in the next wk, but also another thing is it kinda jerks into gear when shifting from 1st to 2nd
