What's that round thing connected to exhaust manifold?
Discussion in 'The Garage' started by MilpitasK5, Dec 19, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    What\'s that round thing connected to exhaust manifold?
    I didn't see exactly how it was connected but it looks like some kind of pump or something. It's on the passenger side. It's round and thick. Probably about 2" in diameter.
    The reason why I ask is b/c it looks like there should be a hose connected to it but it's free. Anyone know what the heck I'm talking about?
    /forums/images/graemlins/ears.gif
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Re: What\'s that round thing connected to exhaust manifold?
    Exhaust heat riser valve? It generally has a chunk of flexible aluminized tubing running from it to the air cleaner.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Does it go to a set of small pipes that feed into each exhaust port? If so, then it's part of the AIR system that is supposed to feed fresh air into the exhaust stream. Fresh air comes from the AIR pump, then into the ports to burn any leftover fuel that couldn't burn due to a lack of oxygen. It reduces emissions and keeps the catalytic converter hot enough to do its job. /forums/images/graemlins/cool.gif
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's the heat riser. From Thorley Headers -
    The heat riser is a valve that closes off the exhaust on one bank of a V-8's cylinders when it's cold. The heat riser routes the hot exhaust gases from the closed off bank, through the exhaust crossover at the center of the manifold, and out through the exhaust manifold on the open side. Heat risers are also known as early fuel evaporation systems (commonly referred to as "E.F.E. valves") There are two types of heat risers: mechanical and vacuum. The mechanical heat riser uses a bi-metallic strip that acts as a heat sensitive spring to open the valve. The vacuum heat riser (shown above) uses a vacuum canister to open and close the valve.
    <font color="green"> </font color>
    [​IMG] </font color>
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Cool pic! I've never seen one of the vacuum operated heat risers! /forums/images/graemlins/shocked.gif I guess I've only seen the mechanical ones that are operated by a thermostatic spring.
  6. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Okay Evan, I'm done thanking you b/c it's getting old /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif.
    Does this need a hose from somewhere to be connected to it? Where do I get it or where should it be from? /forums/images/graemlins/ears.gif
    Thanks guys! /forums/images/graemlins/thumb.gif
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'm pretty sure it gets manifold vacuum. I'll look it up in my service manual if you want. </font color>
  8. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    That'd be great! /forums/images/graemlins/thumb.gif
    Of course, when you get the chance. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. Re: What\'s that round thing connected to exhaust manifold?
    I think you're ALL wrong! That's the muffler bearing. /forums/images/graemlins/rolleyes.gif
  10. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Really? That pic that Shaggy attached is what I was asking about. What are you referring to? /forums/images/graemlins/ears.gif
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    this coming from a guy that can't figure out how to fill out a profile?? /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/ignore.gif
  12. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Awwww how cute!! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif Jokes on the guy that doesn't know crap about engines that and tryin' to learn...
    Thanks for your input too, buddy. Any help is always appreciated! /forums/images/graemlins/rotfl.gif
  13. Grim-Reaper
    7,385
    Atlanta
    The vacuum heat risers are connected to a thermo control valve on the intake or the thermostat housing. If you hook it to straight vacuum it will be closed all the time and cause vapor lock as it boils the gas in the carb.
  14. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    So that sounded like there should be something hooked up to it but not a vacuum line? /forums/images/graemlins/ears.gif
    So is there a hose or something from </font><blockquote><font class="small">In reply to:</font><hr />
    Thanks /forums/images/graemlins/thumb.gif
  15. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Can you still get those?
    I tried NAPA, but they looked at me like I had 3 heads.
    I have yet to try the dealer.
    Any part numbers?
    Thanks. /forums/images/graemlins/thumb.gif
  16. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Ahhh yes, that is correct, sir. Now I remember that from when I had to figure out what that funny lookin thing on my intake manifold is. /forums/images/graemlins/thumb.gif Thanks, Grim. </font color>
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds to me like there is supposed to be a vaccum line that goes to a thermostatic vacuum switch on the intake manifold. Another vacuum line goes from there to the heat riser. When the engine warms up, the heat riser opens and lets the exhaust flow freely. /forums/images/graemlins/cool.gif
  18. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Could that be part of the reason that I get some back-fire/gurgle when cold?
    So does anyone have pics of how that should look connected with the hose/vacuum?
    Sorry if I'm not picturing this right away. Still kinda cloudy /forums/images/graemlins/smirk.gif.
