What's that swirly finish on alum dashes called?
Discussion in 'The Lounge' started by LKJR, Jan 2, 2007.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    we've all seen it, I just can't recall the name of the finish. good ones are done on a mill if I remember right. overlapping swirl pattern in concecutive rows. :confused:
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    Jeweled?
    edit: nah, thats not it. but i know what oyu mean!
  3. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    Non-directional brushed!
    Oh yeah, wtf tech in the lounge? tsk,tsk,tsk...
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    well it's questionalbe on if it is tech or not
    if it was on a fridge it's not tech related right?
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    The phrase is question is engine turned. Don't ask how it got that moniker, cause I don't know.:confused:
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Engine turned. Pontiac used it on the dash plate of Trans Ams in the 70's.
  7. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Is it called fridge turned if it was on a fridge? Just asking.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no, because its engine turned when used on the dash. if it were as you are asking, then it would be called dash turned.
  9. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    :haha: :haha:
  10. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    nah, a fridge is too big to turn around a brush repeatedly, gets heavy...
  11. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i wish i could help,but. i do love the description.:haha: :haha: :haha: swirley:haha:
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its engine turned, we already determined that doofus. :screwy:
  13. boggerless
    May 26, 2003
    22,728
    96
    really Jeremy???like i did not see that!!!:haha: :haha: :haha: :haha: :haha: :haha: OH and FU:D
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Little tidbit : 1980's Silverados with the aluminum looking dash bezels , can be turned white by cleaning with formula 409 . I learned this the hard way .
  15. dyeager535
    26,982
    191
  16. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Engine turning is not hard to do.. real craftsmanship comes from doing perfect circles on compund curves and angles and having them all match and line up
    you can do it at home on your drill press.. or even with a hand powered if your ck5 thrifty....
    some steel wool or 3m pad, a small backup pad.. like 1-2 inches.. 3 m norton.. they all make them.. afix the steel wool to the pad using a rubber band... position piece to receieve finish so that it wont move.. begin making overlapping swrils.. use low speeds... under 250rpm.. its hard to make mistakes when the circles overlap.. just try to keep your lines, generally straight,,,
    cam
  17. dyeager535
    26,982
    191
    So is the jeweling I linked to any different than engine turned?
    I'd seen it called jeweling long before I got into automotive stuff, but it does look like the same idea, just on a smaller scale. Curious if there is a different process or something I'm missing.
  18. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I think angle grinder with varying random patterns might look better.
  19. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    :haha: Got pics?
