What's the best coating to use on Axles, Frame, etc...?
Discussion in 'The Garage' started by IGOR, Nov 24, 2002.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    What\'s the best coating to use on Axles, Frame, etc...?
    I'm getting ready to swap in a 14-bolt in my '72. I'd like to paint it black or maybe blue.
    What's the best coating to use on it?
    Powder Coat
    Spray Paint?
    Por-15?
    Rhino-Lining or Line-X
    Other?
    Thanks for your feedback...
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Re: What\'s the best coating to use on Axles, Frame, etc...?
    I'd think Por-15? for some thing like that...
  3. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Are you following me? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    I'm lonely... /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    From what I've read the POR is badass but not for things that need to look purdy because of the finish and you have to use a grinder to take it off....
  5. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    I was thinking Por-15 as well, - but then I have a friend that does powdercoating - so what about that?
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Don't you have to put things through a furnace to be coated??? /forums/images/graemlins/eek.gif
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
  8. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I did spraypaint... only because i was too lazy to go get por 15
  9. Re: What\'s the best coating to use on Axles, Frame, etc...?
    i used semi-glos black hi-temp spray paint for a front a while ago, its been sitting on the side of my house for 9 months, and stilll rust free.
  10. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I got a gallon of just cheap gloss black enamel and sprayed the whole frame axles springs ETC. IMO if its shiney, its smooth and not much will stick to it for easy cleanup after a ride. I havent tested my theory yet since I have only washed the Blazer once in all the time Ive owned it, and what is on the frame is pretty well caked and baked on. /forums/images/graemlins/tongue.gif Had I sprayed down the underside when I get back from a ride, I am pretty sure it would have rinsed off decent.
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    So with POR 15 you have to use a grinder to get it off forreal? and its not pretty?
  12. chevyfumes
    Feb 24, 2000
    38,584
    266
  13. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Chrome! /forums/images/graemlins/thumb.gif
    Bling Bling!!
  14. IronMan
    IronMan 1/2 ton status
    Nov 16, 2002
    223
    Bay Area, CA
    I used POR-15 when I restored my 74' CJ-5. It is a very tough coating if applied properly. Make sure to top coat it as soon as possible. Areas that were not immediately top coated peeled. Others that had been are still perfect. It applies well with a brush (you'll need alot of cheap ones).
  15. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Rustoliums Hammer Right rust inhibitor. I have a pic of the can if find it I will re-post.
    I used it on the frame axles, springs, hangers, traction bars, back side of rockers, all the steering.... Basically everything under the truck. 5 cans @ 4.97 each. Very little rust has popped back through. Might need 1 or 2 cans to touch up next summer.
    They have silver(met), dr silver/grey(met), black(met), muddy red color and I think yellow and blue? I got mine at a lowes store. Pretty good stuff IMO /forums/images/graemlins/thumb.gif
  16. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Hmmm--that's funny don't remeber seeing any chrome on your /forums/images/graemlins/k5.gifin the indy pics Steve posted awhile back /forums/images/graemlins/rotfl.gif
    Duh, what gives /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  17. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Well, I would have said a few layers of line X would have worked probably the best for the axles, but... its thick! and it needs to be applied by a professional. I'd go with POR15, I've had pretty darn good results with it. Top coating isnt necessary, but it gives it an extra bit of protection. Though 4 layers of por15 is pretty darn tough too.
  18. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    First I took a wire brush to everything and started painting.
    OK, here come the pics
    Well well before brush in bedliner
    after
    The brush in bedliner makes it easy to cleanup fast, just scrub with a tire brush or the brush at the car wash and it come back to the gloss look and the rocks dont make near as much noise.
  19. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    POR 15 is the way to go, the finish is not bad, just alot of time involved in the prep, and if you don't follow the instructions it won't work.
    [​IMG] /forums/images/graemlins/k5.gif [​IMG] [​IMG]
  20. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'm not a big fan of thick expensive finishes since they can be hard to touch up and hard to remove if you need to build-rebuild-modify. No matter what I'd make sure it's relatively cheap and easy to apply since you will be scraping the axles on stuff and they will need touch up.
