What's the best drill bits to use?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Aug 7, 2001.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    What\'s the best drill bits to use?
    Got some drilling to do on my frame. Two holes up to 1/2". I'm wondering what's the best drill bits to use on hard steel like this. Is there a difference drilling frame steel as opposed to mild steel? Can I just use a regular hole saw or should I graduate bit sizes up to the proper diameter or do they make a super dooper bit that'll chew right through it?
    Stuck is a state of mind!
    Mudstud
    76K5 sb400/350/203parttime/3.73-D44/GM12 locked
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Re: What\'s the best drill bits to use?
    I have tried out a bunch and most work... just keep them well oiled up and give them breaks every so often to cool down... The best results I ever had were with the cobalt bits... I broke one I used it so much and took it back to Sears and they replaced it. Good deal if you ask me! [​IMG]
    C'mon captain break pedal... quit looking for the parade and drive!! [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
    &lt;&gt;&lt; MARK 1:17 &gt;&lt;&gt;
  3. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    titanium coated ones rule..... i bought a set from dewelt that are titanium coated and they work very very well
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, edelbrock performer intake+carb, MSD pro billet http://communities.msn.com/68K10
  4. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    norsemen are the best... we use them at work on hardened steel, work pretty well. When you drill, start with a small pilot hole and work your way up bigger and bigger.
    Shane
    Never argue with idiots; They will drag you down to their level and beat you up with experience [​IMG]
  5. Medman74K5
    Medman74K5 Registered Member
    Jun 7, 2001
    48
    Arizona, Prescott Valley
    I've had good luck with titanium coated bits. Haven't broke one yet.
  6. Storm Trooper
    Nov 24, 2000
    4,640
    Yes there is a difference. The titanium bits hold up better in my opinion. As for hole saw bits. I recomend Lenox brand bits. I use them all the time for work and have found them to also hold up better than others. You may want to use a titanium pilot bit or pre drill the hole for the hole saw with one. Most of the hole saw pilot bits are junk. If you need to cut some hard metal like spring bolts etc. Lennox makes a grit type saws all blade that works great and holds up. I tried standard metal blades and they kept frying. The grit edge blades just kept cutting and cutting. I was suprised. I didn't even think they would cut much. There is a bit recommendation under the Potent Rodent (Shawns project) when installing rock sliders. <a target="_blank" href=http://offroad.com>offroad.com</a>
    By the way, working up in size is a good idea with reg. drill bits (helps them last).
    Good luck, hope this helped Dan.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"8" Lift -<font color=purple>38.5's"[​IMG]....
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yes get some titanium coated bits they last the longest and are worth the extra bucks
    ~~'84 K5~~
    Check it out at:
    <a target="_blank" href=http://www.k5.rockcrawler.com>www.k5.rockcrawler.com</a>
  8. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Thanks guys. Appreciate it.
    Mudstud
  9. ImpalaSS
    Feb 1, 2001
    201
    also the dewalt ones have little pilot holes on the end which really help
  10. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    SHARP ONES are best
  11. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Someone else's.........
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  12. michaelm
    Feb 2, 2001
    872
    Hey those are the ones that i used, they worked great...for a while
  13. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I did it both ways, right to business with a 1/2" bit (seemed to take forever), then I started small and graduated to 1/2" (1/4", 3/8", 1/2") Seemed to quicker.
    Use sharp bits and slow speed also use cutting fluid to lube.
    John
    John
  14. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    The frame steel is actually mild steel. The drill bits that you should use are Colbalt Screw Machine length (short) not Hight Speed Jobber length (long) and the other posts are correct when they say use several graduated steps up in size and use lots of cutting oil and slow speed on the drill motor. Heat is the worst enemy.
    <font color=red> Bill, "Shop Rat" </font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Shop-Rat>http://coloradok5.com/gallery/Shop-Rat</a>
  15. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Go to Sears and get a Titanium Step-drill bit(uni-bit), a standard uni-bit will also work, but won't last as long. They work great for this kind of stuff. Just make sure you go slow, don't let the bit overheat, because once it does, it's worthless.
    73K-5: TBI350/TH-400/NP-203/14FF/D44
    Topless, doorless and no tailgate!
    Fresno, CA
  16. NoRulz
    NoRulz 1/2 ton status
    Feb 6, 2001
    388
    Mesa, AZ
    I agree with Jason, Uni-Bits kick ass for drilling frames...
    So do RotaBroachs...
    My Ford has chevy parts! it's all good!
  17. Jason73K5
    592
    Fresno, Ca
    I'd forgotten about the RotaBroachs. I've gotta get me a set of them someday.
    Fresno, CA
  18. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    So what is a RotaBroach? Thanks for all the replies.
    Mudstud
  19. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Rotabroaches are basicly mini hole saws. They are great but they are also kinda fragile. If your going along and it grabs hard the saw part will drop teeth or shatter. Ive killed more than my fair share of them.
    Any way you go use a slow speed and plenty of oil to help cut and to cool the bit.
    I get all the excercise I need pushing my luck![​IMG]
  20. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Snap-On rules!
