What's the best limited slip/posi? how much?
Discussion in 'The Garage' started by 86sierra, Jun 30, 2004.
  1. 86sierra
    86sierra Registered Member
    Oct 31, 2003
    9
    What\'s the best limited slip/posi? how much?
    I have an 86 longbed K1500 with 4" lift and 35" BFG AT's. It will probably never see offroad use serious enough to need a locker. Before winter I plan on having 4.56 gears and a limited slip put in while they're in there.
    What's the best limited slip or posi to go with?
    How much can I expect to pay for the gears/ rear limited slip including install?
    Is 4-wheel parts in Indianapolis an okay place to use or would I be better off looking for someone local?
    Thanks.
  2. dyeager535
    26,977
    Re: What\'s the best limited slip/posi? how much?
    If going with gears, and paying a shop, I'd say easily $1000 or more. Price obviously depends on where you are though.
    As far as limited slips (clutch type) I would speculate that the Eaton is the #1 choice. They come in a couple of spring configurations, (changes how much load before they slip) which with tires that large, would probably be a necessity.
  3. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    the detroit truetrac I ran one for a while and loved it and they dont wear out
  4. macg
    macg Registered Member
    Dec 3, 2003
    17
    Floresville Texas
    I got a quote from two places in Houston for a Dana 44 and 12 bolt, one wanted $1400 the other wanted $1600. They said limited slips would be about $300 each.
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Where are you at around indianapolis?
    If you join IFWDA (indiana four wheel drive assocation) you get 10% off at 4 wheel parts in Indy. Shoot me an email jjlaughner at hotmail.com and I'll give ya some more details. If you join IFWDA through HoosierK5.com its cheaper also... /forums/images/graemlins/waytogo.gif
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Eaton
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I've ran both the Eaton Posi (carbon fiber clutches) and the Detroit Tru-Trac, plus several OEM limited slips.......the Tru-Trac has been my favorite by far.
  8. 86sierra
    Oct 31, 2003
    9
    I'm located about 70 miles north of Indy up Interstate 69. jjlaughner, you've got mail.
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I wood vote for the Eaton(with carbon fiber clutches)for
    the best Possi/Limited Slip.
    /forums/images/graemlins/peace.gif
  10. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i vote carbon fiber clutch eaton, put the beefier springs in it & let it rip. i run mine in my dd w/ 36"s & the heavier springs w/ no problem.
    eaton costs about $500 & they have been off & on national backorder here lately.
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    yep, same thing here, well they were anyway, for a while, just ordered one today i belive.
