What's the best tire pressure for different surfaces?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by LAZYMON, Dec 9, 2000.
  1. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    What\'s the best tire pressure for different surfaces?
    I was wondering if anybody has a chart or something like that advising what the best tire pressure would be for different surfaces like:
    Ice=======
    Deep Snow=
    Mud=======
    Rocks=====
    Gravel====
    Sand======
    Freeway===
    I know this probably varries with tire and rim size so maybe that could be included also.
    I have ProComp 35X12.5X15 on 8" rims.
    PRAY FOR SNOW!
  2. Bri's88Jimmy
    Bri's88Jimmy Registered Member
    Sep 1, 2000
    9
    Dover, NH, USA
    Re: What\'s the best tire pressure for different surfaces?
    On the highway I run my tire pressure at max the ride is rough but gass milage is a little better. I would say that what you listed your tires should be ared down low to about 12 lbs per squar inch so you have a bigger foot print so that you won't sink down. Ice I'm not shoure about.
    Hope this helps Brian
    88 jimmy stock
    rebuilt engine
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Tire pressure is kind of a trial and error thing. The variables are too vast to have one chart for everyone.
    I run 35x12.5x16.5 MT's.
    Freeway- 30 psi rear, 32 psi front.
    Same for ice, deep snow, and mud. The truck is too heavy to float anyways.
    Rocks-15 to 18 psi. any lower and I'll lose the bead.
    Gravel road-24 psi, enough to soften the ride.
    I've never had my truck on sand, but I would likely let as much air out as possible.
    Rene
  4. SANDMANPHIL
    SANDMANPHIL Newbie
    Nov 16, 2000
    4
    I HAVE 35X14.50 INCH MICKEY THOMPSON TIRES ON 15X10 RIMS. IN THE SAND I RUN 4PSI OF PRESSURE ALL THE WAY AROUND. 4PSI OFFERS GREAT FLOTATION IN THE SAND. I HAVE NEVER BEEN STUCK! ON THE HIGHWAY I RUN 10PSI OVER THE RECOMENDED MAX PRESSURE AT 30PSI.
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    on the trail I run 12-13 up front and 10 in the rear on BFG 35X12.5 MT's on 10 inch rims. I have not rolled a bead yet and this pressure seems to work good for me
    I thought I was wrong once,
    but I was mistaken
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Same as Butch, although I have run down to 8 psi, and poked 2 sidewalls as a result- SW desert trails
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  7. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i run 30 on the highway, on soft sand 10-15psi. (33X12.50 BFG ATs)
    Knife.
    knife.coloradok5.com
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yep I have 33x12.5x15 Dunlop MudRovers on 10" wheels and the sand and trail crawlin is between 12-16 psi.
    Anyone air down for snow?? Or a snow coverd road, hardpack??
    http://www.burt4x4.coloradok5.com
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It also depends on the tire itself. BFG's flex pretty nicely at 15-18 psi. But I've seen the big bias ply Super Swampers aired down to 18 (38's on a 440 powered Ramcharger) that barely flexed at all! [​IMG]
    http://ThunderTruck.ColoradoK5.com
  10. 65FL
    65FL Registered Member
    Apr 11, 2000
    31
    Castle Rock, CO
    I've been ice racing a few times, most people in the stock class air down
    to about 7-10 PSI. I have to agree with others. Try different pressures and
    see what works best for you.
    65fl
