>>>>What's the best valve cover gasket?<<<<<
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Oct 21, 2001.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    >>>>What\'s the best valve cover gasket?<<<<<
    What do y'all recommend? Rubber, cork, RTV, bubble gum etc etc. Cost is not a factor.......
    ~~'84 K5~~
    Check it out at:
    <a target="_blank" href=http://www.k5.rockcrawler.com>www.k5.rockcrawler.com</a>
  2. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Re: >>>>What\'s the best valve cover gasket?<<<<<
    I use VICTOR-REINZ 5/16" thick cork-rubber gaskets. Twicce as thick as std gaskets. I think thr # is vs38110htc. Never had a leak with this gasket.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  3. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    Rubber felpro gaskets with permatex ultra black rtv.
    eric
    Don't get me started, you know how i get.
    82k5, 14bff, d44, sm465, np205, 300hp350, rust
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I use Felpro, I can't remember what they call it but it is cork and has metal inbetween two pices of cork so it's double thick! I have had no leakage sence I put theas super thick cork ones on!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I use Felpro also.I put them on dry (no RTV) and torque them to spec.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  6. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If you are confident in your work, (valve adjustments) just weld them on....
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/chevyracing>http://community.webshots.com/user/chevyracing</a>
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    I like the Felpro ribbed rubber on both sides and metal in the middle. They cost a lot more than a piece of cork or paper, but you can reuse them and no messing with the cure time of RTV. And most importantly, they don't leak. I suppose that a small block Chevy that doesn't leak oil is kind of like a politician that doesn't lie...
    <font color=green>There's nothing like the smell of a rich V-8 in the morning...</font color=green>
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I had some Fel-Pro perma dry plus rubber gaskets and they liked to leak. I do have alumminum edelbrock valve covers which have a differnt flange than stock so I guess its probably not the gaskets fault. I switch to the Fel-Pro blue stripe cork gaskets and have not had a leak since.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  9. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    GLAD TOO HEAR IT ,JUST GOT SOME EDELBROCK ALUMINUM COVERS (ELITE SERIES) (AHHHH stupid caps lock) and also went with the blue stripes....[​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
