What's the biggest spare you've fit in your 'burb?
Discussion in '1936-Present Suburban' started by heavy4x4, Mar 1, 2003.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What\'s the biggest spare you\'ve fit in your \'burb?
    Well, thought the forum could use a new post, so here goes:
    I'll be putting in 3/4 ton axles this summer if all goes as planned, and thus I'll need new wheels. I'll also need a new wheel for my spare - and I figured while I'm at it, why not get a spare that's closer to the tire size I'm running (I always figured if I got a flat, I'd just put the spare on the front and stay in 2wd). So, what size tire do you have in the spare-wheel well? I took some rough measurements today and it looks like I won't be able to go higher than 30" and wider than 10-10.5" /forums/images/graemlins/frown.gif
    I know some of you will just say - awww, just toss a 33 incher on the floor of the back and be done with it. Well, I'd rather not do that - having it slide around and all, and even more bothersome to have to move it whenever I'm loading something.
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Re: What\'s the biggest spare you\'ve fit in your \'burb?
    I've got a 285/75/16(33") stuffed in there right now and it only pushes the seat forward a little. I bet you could go a little bigger. This tire is the same hieghth as a 305/ but not as wide and makes a good spare if you run those.
  3. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    you could put it on your roof, or get a rear spare carrier. the biggest problem with the roof ( as I learned) is getting the damn thing hiked 8 or 9 feet into the air without killing myself. probably would be a good idea to get a rack of some sort to keep it from caving the roof, or breaking the support crossmembers.
    -Rich
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    My plan is building a custom rear bumber with a spare carrier which will hold up to a 40. ANyway, My buddy with a 89 conversion sub squeezes a 36x12.50x16.5 hummer tire in his spot. Okay, it doesn't actually fit, but it doesn't move either. Since his 3rd seat is not as wide as a standard 3rd seat he makes it work. Also, with the space still under his tirs, he puts oil, tranny fluid, anti-freeze, etc. Works really well for him.
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  5. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I'll have to fall in the throw a big tire in the bed and tie it down category. I have a spare that measures 38.5x11x16. I really don't want to be rolling down the road with a tire that's 5" shorter than the rest.
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I have a 35x12.50r15 as a spare in mine, kinda. I used to straps to hold it in there, because it is a little too wide. I just attached the straps to the two bolt holes that are there. I dont have a third seat though.
    Dan /forums/images/graemlins/burb.gif
  7. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i dont have my 3rd seat in so i just set the 35x14.50 spare on the floor on the back.
  8. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    I have a 33x12.50 15 back there. It's tight, but it fits. I just use a strap to tie it down (Please keep your spare tied down somehow). It's a bit of a pain to get out, but it fits. I usually use the tire iron to pry it out from the bottom when needed. I too hae no 3rd seat
