what's the bolt pattern and offset on stock wheels?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 75K5, Mar 29, 2001.
  1. 75K5
    75K5 1/2 ton status
    Mar 14, 2001
    268
    Michigan
    what\'s the bolt pattern and offset on stock wheels?
    What wheels are compatible with my 75 blazer? Any Newer chevy wheels? Do you guys know the bolt pattern, and offset?
    Thanks,
    Brian
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: what\'s the bolt pattern and offset on stock wheels?
    The normal stock wheels that people like to use are 15X8 with 3 1/2" backspacing. They have a 6 on 5 1/2" bolt circle. Any GM full size 4WD wheel from '67 to '87/'91 will fit. Look for the '73 and up 15 X 8 rally wheels. They are pretty easy to find, and will work good for 31 - 35 inch tires from 9.50 to 12.50 width.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Once they went to the IFS, the backspacing is a lot different...
    As long as it had a straight axle in the front and it has the same bolt pattern as you do..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "Pimpin aint easy!"
