what's the deal with headers
Discussion in 'The Garage' started by francis, Dec 25, 2005.
  1. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    hello peoples. In my research on ebay I have found that some headers are listed as 2wd only while some are 2wd and 4wd. Whats the deal? also some people list that their part as like 70 something to 86 and 88 to 90 something. leaving out 87 altogether which is the year of my truck!! and others up to 87. but what is clear is something changed in 88 so that things will not interchange. (am I makeing any sense):confused: anyway does anyone know what changed or happened or what?? any info or opinons great.
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    73-87 for axles, transmissions,engines etc.
    73-80 for interior and things like that
    81-87 interior junk and what not (for pick ups) and 81-91 for blazers jimmy and suburbans
    just about anything mechanical other than fuel stuff for the TBI unit is the same. others will chime in with more info.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    In '88, the new CK trucks came out (leaving K5 and Suburban on the old style til '91). That is probably what your seeing in the catalogs for headers.
    You should be able to use anything '73-87.
    What vehicle and motor are we talking here?
  4. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    A 2wd header will usually run into interference problems at the collector and front spring shackles in my experience.
  5. francis
    Oct 11, 2005
    79
    kemp, texas
    but they look the same.
  6. the beast
    Oct 15, 2003
    535
    Providence, RI
    In many cases they will look the same. Until you put them side by side. The angles that the tubes are bent at may be slightly different, or the end of the primaries and the collectors could be shorter. It varies by manufacturer.
  7. theitalian404
    theitalian404 Registered Member
    May 7, 2005
    75
    Georgia.
    the difference is usually noticable around the collector tubes....angles, and length.(from main pipes to collector). But as 73K5 said.. "What vehicle and motor are we talking here?"
  8. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    just because they look the same doesn't mean they are. turds and baby ruth bars look alike. king snakes and coral snakes look alike too. you'll need to weld in a bung for your O2 sensor in your headers. on my 89 k5, i had to ding one side of the left collector to clear the oil filter, and the other to clear the spring shackle. so there's a little difference between 2 and 4 wd headers.
    evan
  9. francis
    Oct 11, 2005
    79
    kemp, texas
    turds and baby ruth bars look alike. thanks man! i see you've been there and done that.
  10. big_black_blazer
    Dec 19, 2004
    114
    Western Kentucky
    yeah. i know. i was like "man, this has nuts in it. i hate nuts, they taste like sh!t!" and they was like "man, that is sh!t". when did they start puttin corn in a baby ruth bar?
  11. francis
    Oct 11, 2005
    79
    kemp, texas
    this is an 87 k5 blazer with a 350
