What's the deal with new chevy fuel pumps?
Discussion in '1992-Present Chevy & GMC models' started by grizzlyoffroad, Dec 10, 2006.
  1. grizzlyoffroad
    grizzlyoffroad 1/2 ton status
    Mar 31, 2006
    100
    Soldotna, Alaska
    :frown1: How can Chevy not stand behind their fuel pumps???? They obviously have a problem. Every newer Chevy that I or any of my friends own has lost the fuel pump at just over 50k miles. I was talking to my buddies at the local parts store and they say that they sell 2-3 new fuel pumps EVERY WEEK....and we live in a small town. Has Chevy fixed this problem now that they are extending the factory warranty....I'm sure they have, now that is will be costing THEM money. What are your thoughts
  2. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    that happened to my grandmothers suburban at about 93,000 miles. i to live in a small town and they say they have to fix at least 3 every other week. my grandmother just recently bought a new suburban. the guy that she talked to on the phone says that they have made some changes so it doesnt lose pressure. what they did though idk, but thats been the only problem we have had on our newer chevy's. other than that they have been fine.
  3. grizzlyoffroad
    Mar 31, 2006
    100
    Soldotna, Alaska
    What's crazy is that it is a fairly easy fix, just a pain getting the tank out, and the shops want $1000-$1500 to fix it. The part is only $300 and it took a buddy and me about 3 hours to do the last one. Wow, that's some shop markup.
  4. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    It's not just chevy, Dodge has some real ****ty pumps too! At least it's cheap if you do the work yourself.
  5. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    guys..pumps are dying early because they aren't getting lubed by the fuel anymore. the EPA reduced the sulfur content in gasoline starting last june, and sulfur acts as a lubricant in fuel. ( just like a diesel ). furthermore, ethanol , which is being used as an oxygenate, contains alcohol which reduces a fuels lubricating qualities even further..
    warranties don't cover parts that die from lack of lubrication, they only cover materials and workmanship.. since gm doesn't make your fuel, well, you know..
    Tom
  6. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    her's my $.02, I am a mechanic, and from what I have seen, on alot of these newer trucks, when the pump goes, which is fairly often, the fuel filter is either original, or hasn't been changed in quite some time, also the gas in the tank cools the pump, so all these trucks running on 1/4 tank or less are killing there pumps. I personally would change the fuel filter every 12k, and when you do, take it off and shake it and pour it out the inlet side, and watch the mud flow. now i'm not saying that chevy's don't have a problem, but this aids in the pump failure.
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    sounds good, but Chevy fuel pumps have been a fairly known problem for a lot longer than since "last june".
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    x2. this is a very common problem for quite a long time.. its not alwasy the fuel.
    The point about the pump getting too hot is quite possible though...
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I could see that as a possible issue. I don't really worry about it. I've never had a pump go bad on one of my trucks (knock on wood), but they aren't that big of a pain in the ass to change if I have to.
  10. HOSS874X4
    HOSS874X4 1/2 ton status
    Apr 17, 2005
    118
    DALLAS TEXAS
    chevy has a recall out on the 99 and up models for the wiring shorting out and taking the pump with it the recall replaces the wires,connector and fuel pump
  11. badger red
    badger red 1/2 ton status
    Jul 30, 2004
    208
    south central KS
    I guess I've been fortunate--my '01 HD has 113K and no pump problem yet, but i do change the fuel filter regularly and try not to go below 1/4 tank. Does anyone know when the recall was issued or any other details?
    Jeff
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    hell I know when it is time to fill my truck when I jump on it and it bogs. I run that thing so dry EVERY tank, that if that was the killer of fuel pumps, I'd have gone through a hundred by now. I coasted in 2 tanks ago, literally didn't want to maintain idle anymore. Haven't changed the fuel filter in over 30k miles(siezed in place, have to custom fix that...)
    knock on wood...
  13. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    I'll also vote for this one!
    I always fill up when I get gas and my pump has over 225,000 miles on it....
    Did I just jinx myself?:eek1: *knocking on wood*
    Of the family member vehicles that I know of (about 5 or 6 'newer' full size chevys) they haven't needed pumps in their 200,000 mile lifespan.
    On the other hand, my buddy who only puts 1/4 tank in at a time, well... he's changed a few pumps.
    Take it for what it's worth. Just one guys experience added to the story...
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    all manufacturers say the killer of pumps is running them on empty all the time(heat and lubrication factors), I've been lucky most likely, but I'll continue to be until I need a pump, haha.
  15. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    August 8, 2006
    The National Highway Traffic Safety Administration is ordering the recall of 38,439 General Motors SUVs and pickups because of a potential fuel leak that could result in an engine compartment fire.
    GM is recalling the 2004 Chevrolet Avalanche, 2004-2006 Chevrolet Avalanche 1500, 2006 Chevrolet Kodiak, 2004-2006 Chevrolet Silverado, 2004-2005 Chevrolet Suburban, 2006 Chevrolet Suburban 1500, 2004-2006 GMC Sierra, 2006 GMC Topkick 6500, and 2004-2006 GMC Yukon XL.
    NHTSA reports that some of the GM trucks equipped with the 8.1 liter V8 contain a fuel rail pulse damper retainer clip that can fracture resulting in a fuel leak which is near an ignition source in the engine compartment.
    Dealers will replace the fuel rail damper free of charge when the recall begins. Owners may contact 1-800-630-2438 and GMC Trucks 1-866-996-9463.
    Here are some more things from GM
    GM FULL-SIZE (C/K) TRUCK
    & SPORT UTILITY FACT SHEET
    All Technical Service Bulletin (TSB) are either Chevrolet or GM broadly.
    Brakes:
    Improved pedal feel 1984-89 All Models (88-300-5 & 88-311-5); Brake
    rotors 1988-90 C/K pickup (90-379-5); Slush on parking brake cable 1988-89
    C/K (89-288-5); Brake noise 1990-92 C/K (92-166-5); Lead/pull, front brake
    wear 1992-99 C/K, Suburban (86-50-20A, 99-05-24-001).​
    Engine/Driveability:
    4.3 V6: Idle rise between shifts 1989-90 with manual
    transmission (90-320-6E); Engine overheats 1987-88 (88T07); Main bearing
    failure 1996-98 (87-61-22); Rough idle after cold start 1996-98 (87-65-07).5.0/5.7 V8: Engine overheats 1987-88 (88T07)
    & 1988-91 (91-145-6B, 91-167-6B & 91-224-6B); Rough idle after
    cold start 1996-98 (87-65-07); Bearing knock 1996-99 (99-06-01-003).
    6.2 diesel V8: Black smoke at idle 1988-89 (89-181-6E); Difficult/no
    cold start/no restart 1983-89 (89-39-6 & 89-264-6E). 6.5L
    diesel: Hard/no start 1994-99 (87-63-04; No start/stall 1994-98
    (77-63-06A); Hesitation, rough idle, power loss, hard/no start, stall
    1994-98 (87-63-03, 87-65-13); Replace injection pump 1994-99 (87-63-07);
    Long crank on hot starts 1996-99 (87-65-25). 7.4 V8:
    Surge 1987-88 & 1996-99 (88-162-6E, 88-195-6E & 99-06-04-016);
    Engine overheats 1988-91 (91-167-6B); Belt noise/wear 1988-89 (89-61-6B);
    False "service engine soon" light 1987-89 (89-263-6E); Engine noise 1988-90,
    1996-99 (90-299-6E, 99-06-04-014); High oil pressure 1992-93 (93-8C-31).
    All: Reduced performance 1988-91 pickup (91-139-6C);
    Starter grind/clash 1985-88 (88-305-6D); Oil cooler line leaks 1988-89
    pickup (89-208-6A); In-tank fuel pump loose 1987-88 Suburban (88-137-6C);
    Engine roughness 1987-88 (88-40); Engine noise 1982-93 (376602); Oil consumption
    guidelines (1 quart/2,000 miles) & tests 1996-99 All gasoline models
    (76-60-04A).​
    Steering/Suspension:
    Free front end alignment kit with greaseable ball joints 1988-90 C/K (90-277-3C,
    90-392-3C); High P/S effort 1988-91 C/K (88-308-3B, 88-415-3B,
    91-173-3B); Steering "hoot" 1988-89 4x4 C/K (89-55-3B); P/S pump pulley
    misaligned 1996-98 C/K (77-60-02); Reduced steering effort '97-98 C/K
    (86-32-06).​
    Transmission/Drivetrain:
    Cracks/leaks 1988-92 All 6.2L diesel models (92-182-7A); Clutch chatter/shudder
    1988-90 C/K (90-336-7C); Vents leak fluid 1988-90 C/K (90-252-7B); Transfer
    case leaks 1988-92 K pickup(91-508-7D); Clutch hydraulic system fluid
    leaks 1992-95 C/K with A/T (66-73-01); Fluid leak 1995-96 C/K, 1996 Bravada
    (57-71-26); Clutch chaffer/shudder on launch 1994-95 C/K with 4.3L, 5.0L
    or 5.7L engine (66-73-04A); No upshift 1995-96 C/K with 4L60-E or 4L80-E
    A/T (57-65-08A); Lack of power, early shifts, late shifts, or erratic
    shifting 1993-96 All models with 4L60E & 1994-96 All models with 4L80E
    (343); 4th gear loss/slip, 3-4 busy shift, TCC cycling 1996-97 C/K with
    4L80E (77-71-7); Slow or no engaement of front axle when 4WD selected
    1988-97 (76-43-01A); 4WD inoperative 1998-99 C/K (99-04-21-002); Transmission
    fluid low, transfer case overfill 1996-98 (86-74-04). For more
    info on GM transmission defects, go to GM RWD Transmission.
    Other:
    Wiper chatters/streaks 1988-90 C/K (90-323-10); Odometer seizure/dust
    1988-91 C/K (91-92-8C); Wind noise/cold air intrusion at doors 1985-86
    C/K & 1985-89 utility/Suburban (90-347-10); Tailgate window chipping
    1985-87 utility/Suburban (87-T-75); Slow power tailgate window 1984-88
    utility/Suburban (88-317-10); W/S washer pump fails 1985-86 All Models
    (86-C-06); Inoperative reverse lights 1980-91 (91-4598A); Reduced power
    assist 1988-92 (92-333-3B); Tire slips on wheel 1988-93 (93-3E-63); Tire
    damage 1991-93 (93-3E-19); Rear axle vent leaks 1993-96 C/K with 10.5"
    rear axles (56-42-03A); Fuel gauge fluctuation 1995-97 C/K (76-83-05);
    Fuel gauge shows empty with 7-8 gallons left 1995-97 C/K (76-83-03A);
    A/C odor 1993-99 (99-01-004); Reduced range of Remote Keyless Entry 1997-99
    (86-90-06); Front seat belt bunching, replace retractor assembly 1999
    Silverado, Sierra (86-16-20).​
    MAJOR SAFETY RECALLS
    Copies of recalls may be obtained from NHTSA's Technical Reference Division
    through the NHTSA Auto Safety Hotline at 888-327-4236. Unless otherwise indicated, all recalls apply to both
    Chevrolet and GMC.​
    Airbags/Seatbelts:
    194,243 1989-90 C/K extended cab - Seat belt adjustment instructions (90V-170);
    3,651 1995 Suburban, Tahoe, Yukon - Location of airbag label (95V-140);
    8,323 1995 Tahoe/Yukon - Center rear lapbelt improperly routed (95V-081);
    630,099 1994-95 C-series & Sierra - Belt buckle releases (95V-241);
    40 1994-95 C/K Extended Cab with diesel engine - Front belt missing energy
    management loop (95V-242); 279,132 1999 Suburban, Tahoe, Yukon - Airbag
    exceeds neck injury allowable levels under safety standard (00V-122).​
    Brakes:
    63,196 1988 C/K - Hose rupture (87V-136); 50,000+ 1994 C/K - Pedal push
    rod retainer missing (93V-152); 300,000+ 1988-92 C/K 100, 200 - Rotors
    corrode (93V-119); 1,000+ 1998 C-series, Tahoe, Suburban, Yukon, - Rotors
    crack (98V-033); 13,684 1998 C10 - Rear brake line wears hole (98V-226);
    988,587 1994 C-series, Suburban - Brake switch wiring reversed & contacts
    wear out (99V-025); 5,000+ 2000 Sierra, Silverado - ABS motor & Dynamic
    Rear Proportioning system inoperative (00V-055); 3,758 2000 Suburban -
    Kinked brake booster vacuum supply hose (00V-222); 1,383,922 1999-00 Sierra,
    Silverado, Tahoe, Yukon - Right brake pipe wears at body cross sill (00V-345).​
    Electrical/Lights:
    1985-86 All Models -Headlight failure (86V-131); 36,641 1995 Suburban,
    Tahoe, Sierra, Yukon - "Park" indicator light fails (95V-139). ​
    Fires:
    976 1994 C/K Short Bed - Fuel tank sags (94V-030); 2,595 1992-93 Chevrolet
    C10, C20 & GMC C15, C25, Sierra - CNG tank cracks (94V-044); 3,493
    1994 GMC C-series cab-chassis - Fuel tank straps crack (94V-187); 10,000+
    1995 C/K & Suburban/Sierra - 4L80-E A/T case casting leaks oil onto
    exhaust system (95V-026); 623 1996 C/K pickup with 7.4L engine - Fuel
    rail assembly leak (95V-243); 1,702,880 1988-93 C/K - Transmission vent
    tube leaks (93V-016); 55,272 1995-98 Chevrolet C10, GMC C15 Crew Cab -
    Fuel tank cracks or wear hole at front inner corner (98V-187).​
    Seats:
    303 1993 C/K - Seat becomes detached due to improper rivet (93V-163);
    1,375 1994 C/K - Seat loose due to missing bolt (93V-216); 1,720 1995
    C pickup - Driver seat collapses (95V-027); 624,433 1995-97 C/K Extended
    Cab & 2-door Utility Vehicles - Recliner mechanism on Easy-Entry feature
    pinches hands or severs fingers (97V-037); Seat back suddenly reclines:
    250,000+ 1989-90 Suburban (93V-187), 2,400 1994-96 C/K (96E-010), 675,661
    1993-94 C-series Extended Cab (95V-246), 32,596 1991 Suburban (96V-226),
    57,264 1992 C/K (99V-130); 6,418 1997 Chevrolet C10, C20 & GMC C15,
    C25 - Seat mounting bolt missing (97V-176).​
    3,047 1995 C-series - Steering shafts separate (96V-004); 30,148 1994
    C/K - Loose lower control arm bolt (94V-060); 2,750 1988 C/K - Tie rod
    nuts fall off (87V-126); 15,000+ 1996 C/K - U-bolts nuts on rear axle
    loosen/fall off (96V-082); 3,957 1998 Chevrolet C10, GMC C15 - Steering
    shaft separates (97V-142); 8,367 1999 Silverado, Sierra - Steering gear
    separates (98V-242); 1,462 2000 C35 - Steering linkage improperly assembled
    (00V-054).​
    Other:
    8,893 1988 C/K - Cruise control cable lock mechanism disengages (87V-125);
    1,521 1988 C/K - Cracked/broken striker nuts cause door to open (87V-127);
    29 1994 C/K - W/S separates (94V-212); 379,004 1995-96 C/K, Suburban,
    Tahoe, Sierra, Yukon - Throttle sticks (96V-057); 5,000+ 1995-96 C/K with
    General Ameri*550 tires - Sidewall bulges &/or flat tire (96V-117);
    73,162 1995 Blazer/Jimmy - Fan blade rivets break (95V-180); 5,683 1989
    C/K Extended Cab (89V-078) & 4,821 1994 C/K Extended Cab (94V-057)
    - Hitch failure; 750,000+ 1994-96 Chevrolet C10, GMC C15 - W/S wipers
    fail (98V-150.001); 35,659 2000 Tahoe, Yukon - Exhaust gases enters passenger
    compartment through rear wheelhouse (00V-343).​
  16. jpdrake
    jpdrake 1/2 ton status
    Oct 31, 2005
    381
    mass/ cape cod
    $hity fuel pumps
    i bought my 98 in 00 and have gone through 3 pumps replaced filter 6 times, and gone though 2 tranny rebuilds and 1 replacement had the rear end bushings replaced and a manifold intake gasket, radiator, 3 alternators 4 batt. and a water pump replaced!!!all before 150k since 75k
