Whats the deal with TV reception??????
Discussion in 'The Lounge' started by chevyfumes, May 27, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Why is it when there is anything red on the screen it is filled with white static, does this make sense.... We just got a big screen and it's even worse because everything's huge, it only happens with TV signals.I was wonderind if I get digital cable if it would fix the problem, anyone have any ideas?/forums/images/icons/mad.gif
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Are you using the tv antenna now or do you have cable ...(not digital)
    If its the rabbit ears then that is from the electrical lines and all the electricity in the air...
    And yes the cable should will take care of that problem ( is a new tv ) if it isn't then the problem might lie in the tv connections ( I would check those first anyways....mike
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    I've got cable and it's not the TV it happens on every TV I've evert had where ever I've lived and I've seen it on other TV's but it dosent happen all the time, I was just watching the same commercial that it happened on awhile ago and it didn't happen this time....weird...
  4. potato76
    potato76 1/2 ton status
    Mar 21, 2002
    922
    phoenix, AZ
    it could be the cable co. lines into your house.You should see if your neighbors(if you have any) are having the same problems.If you get a few people with the same prob have the cable co come and check the signal.Digital cable wont help if you have a signal problem.Or maybe replace the co axle(sp?) cables and buy good ones that somethimes helps.
  5. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    You might try a signal amplifier (radio shack has them) It can up the signal that is coming from the line...i.e. if you have a weak signal then the reception sucks and can have channel walk over (seeing 2 channels on one or the grainy look are a sign of a weak signal) I was in florida for a while and the whole house had to have an amp done to get the grainy free picture....mike
  6. potato76
    Mar 21, 2002
    922
    phoenix, AZ
    That might work ive heard of those before.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Doesn't happen over this side of the river /forums/images/icons/laugh.gif............only have a 35" Sony Trinitron tho..............by the way, Digital Cable sucks...........gotta wait like 3 seconds for each channel change.............and for a guy that's an eternity!
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Complain to your cable company. Ask if they can send a tec out to fix the problem at no charge to you becouse it's a problem with thier equipment.
  9. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I had that problem on an old tv. We got a new TV a year or two ago and it went away. I'm wondering if I just had a bad connection that went away when I changed the tv. I actually did put in a filter and splitter when I got the cable modem, that may have helped...
