Whats the deal with winches...
Discussion in 'The Garage' started by 1979Jimmy, Jul 23, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I cant figure out what is the deal with winches what does their capacity really mean. I mean I looked on ebay fior a bit and i see this ity bitty winch for 30 bucks with a 30000 pound capacity and then i see another winch off a 1 1/4ton dodge truck rated at 7,500 pounds. Whats the deal and what do the numbers really mean. /forums/images/icons/confused.gif
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Sounds like some misprints to me. A $30 winch probably pulls 300#, not 30,000.
    I think that winch load ratings are listed at their max rate, which means that you want to find one that's working rate (which is lower) will be sufficient for your rig. Therefore the rule is find one that's max rated 1 1/2 times the weight of your rig. Most guys get 9000# winches, because the gross vehicle weight of a blazer is supposed to be about 6000# or so.
    I bought a 12K Warn because I keep a lot of heavy stuff in my rig and want to make sure I can get out of stuff like snow and mud, and because even I thought a 15K winch was overkill (tho I was tempted anyway).
    Once you have the right weight, then which kind is up to you. Lots of posts on this. Do a search.
  3. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    GVW pf a Blazer is about 4k I think. I have an 8500# PTO and it's rated at that number with only one wind on the spool. Sith two it get's cut in half.
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Actually GVWR on my 75 in 6300 which is not what it really weighs but thats the max its rated for. Actual weight maybe 4500-5500 depending on what you got in it.
  5. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    ALL I KNOW IS A 9000 POUND WARN ALMOST DIDN'T GET MY SUBURBAN OFF THE ROCKS. THE REAL QUESTION WITH WINCHES IS WHAT TYPE OF POWER SOURCE TO USE, HYDROLIC, ELETRIC, OR POWER TAKE OFF. ALL HAVE +AND- 'S. /forums/images/icons/cool.gif
  6. landsmasher
    Mar 13, 2002
    4,423
    Mine is pretty much stock. I'll go weigh it tomorrow and let you know what it weighs without my dog in it. Geeesh I gots ta get her on a diet... SOON! /forums/images/icons/shocked.gif
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I have a 8274-50 warn winch and i can pull a loaded semi up a hill with it. Its all in how you use it. The use of a snatch-block can double its pulling capacity.
