Whats the diff between K5/K10/K20/ etc...?
Discussion in 'The Garage' started by blownK10, Feb 5, 2003.
  1. blownK10
    blownK10 Registered Member
    Jan 23, 2003
    8
    Southern CA, USA
    Always thought it was a size/weight thing. Ive got an 83 K10 Blazer, and a buddys got a K5, looks the same size to me, except his has a 305 and mines a 350. Can anyone tell me the diff between the models or tell me where to go to find out. thanks guys
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    K5 is a Blazer/Jimmy (6 lug axles D44/10b front, 10/12b rear)
    K10 is a 1/2 ton pickup/surburban (6 lug axles, same as above)
    K20 is a 3/4 ton pickup/surburban (6 or 8 lug axles D44/10b front 14b semi or full float rear)
    K30 is a 1 ton pickup/surburban (8 lug D60/14b full float rear)
    It is a weight thing. Engine sizes and bed styles were an option.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The suburban wasn't offered in a 1 ton design....I wish it was. /forums/images/graemlins/smirk.gif
  4. blownK10
    Jan 23, 2003
    8
    Southern CA, USA
    Thanks for taking the time to list out that info for me Ash. Its much appreciated. This Buds for you....glug, glug, glug, ahhhhh..
  5. Grim-Reaper
    7,385
    Atlanta
    All blazers were K5 till 88 even if they were 2wd. For some reason GM flaked on the Blazer K/C designations. C would be 2wd. However they are also listed as a K10 on a lot of registration/ titles and other places because mechanically they are identical to the K10 trucks. My wifes 79 is registerd as a K10 Blazer. My 75 Jimmy is registered as just a Jimmy.
    In 88 the Blazer, Burb, and Crew became designated as "V" so that GM could use the K and C on the new body trucks. Technically this board should be ColoradoV10 because Steve's truck was built after 87. /forums/images/graemlins/rotfl.gif
  6. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    i could have sworn they did...saw one at Uhwarrie last year. had the K30 surburban badge on it. D60 front and a 14b rear.
  7. heavy4x4
    Aug 28, 2002
    3,270
    Must have been swapped in axles and a glued together badge....GM never offered them like that from the factory (in my mind one of the dumbest mistakes - I'd love to buy a burb with all the goodies already in it). Did you know that you couldn't even get a 454 in a 4x4 burb? The 454 was only an option in the 3/4 ton 2WD. /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif
