What's the diff between Radials and Bias Ply tires?
Discussion in 'The Garage' started by stallion85, Dec 3, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    What\'s the diff between Radials and Bias Ply tires?
    What's the diff between Radials and Bias Ply tires? I have always wondered and have never asked. I came to the assumption that Radials are just better for road use /forums/images/graemlins/dunno.gif
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Re: What\'s the diff between Radials and Bias Ply tires?
    Doesn't it have to do with how the metal bands are oriented in the tire?
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It has to do with the way the plies are oriented. Radials are at 90* angles to each other (like this -| ). Bias plies are at a 45* angle. (/\)
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    So are the Bias plies stronger?
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Absolutely.
  6. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    The sections of rubber in a radial tire go around the curcumfrence of the tire to make it ride better and stop flat spots. After doing this they construct a seperate section to be used at the sidewall, usually a couple plys thinner than the tread. On bias ply tires, the sections start at one bead, go over where the tread would be, and end up at the other bead of the tire. This makes the sidewalls about as strong as the tread section, but doesnt make for a nice ride since as it rolls the tire is going over all the different sections of rubber going accross the tire.
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thanks for the info, now I understand it /forums/images/graemlins/grin.gif
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Radials are also mroe expensive, but im sure youve noticed that.
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Yea, that's why i wanted to know what the diff was. I guess bias is the best choice for trail dedicated rigs and radials are good for DD and trail used rigs.
