What's the difference between a D250...Edit: I'm buying it
Discussion in 'The Lounge' started by newyorkin, Feb 27, 2006.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Not really a tech question...
    Anyone know the difference? I thought it was like the Chev C/K designation, but apparently there are 2wd and 4wd D150 and W150's, then I thought the W's were diesel, but I see there are gas and diesel W's...
    I found a 4wd 89 W250 with 72k miles for $1500. I thought the W meant diesel, so I was ready to go buy it tonight...
    So anyone know? :dunno: :dunno: :deal: :1zhelp: :1zhelp:
  2. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    extended cab and non?
  3. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Options Package?
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    IIRC one of them has overload springs and is basicaly a one ton dually only not a dually... but i could be wrong.
  5. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Ok, thanks, I'll check out the springs when I go look at it. I'm surprised how little info there is on the net about it...
  6. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    thats because dodges are the redheaded stepchild of the automitive world.
  7. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    :haha: :haha: You know it. But my Intrepid has been the most reliable car I've owned so far, and I've beaten the crap out of it...
  8. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    It IS like GM's designation of C/K but with Dodge it is D=2wd, W=4wd. There are people who do not use the designations correctly (with GM vehicles as well), but that IS what they mean. If someone is advertising a 4wd D150, then it is actually a W150. Dodge used this coding until the body style change in '94 when all the full-size pickups became BR. With these there is no distinction between 2x and 4x (like Ford with their F-series).
    If you go to look at that 89 W250, check under the carpet/mat as best you can for rot. The older Dodges were notorious for windshield gasket/seal leaks, which allowed moisture to collect on the floorboards thus causing corrosion.
  9. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Excellent, thanks for the info. :thumb:
  10. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    It looks like I'm buying it. I drove it around the block, and it seems pretty stout. Actually, it felt like it could yank a stump out in 5 seconds...
    No rust on the body, which was sweet, and the floor boards were solid. The brake and tranny cooling lines looked really rusty, though, and it looks like the rear main crank seal is probably leaking, it was all sloppy around there.
    It felt like it had a little driveline slap, too, but it also felt like it wouldn't bat an eye at towing a 5000lb trailer... Bouncy as a dang rubber ball, I'm wondering if that's the stiffer springs...
    So did I get a good deal?
    '89 Dodge W250
    $1200
    4x4
    3/4 ton
    Standard cab/long bed
    roll-up bed cover
    bed lined
    body strait and paint shiny
    74,000 miles (:rotfl: the same as our "brand new" minivan that we drive all over the planet)
    runs excellent
    Interior's nice
    Doors, hood, and tailgate all open and close smoothly.
    I think it will haul the bike perfectly. And dirt/log/furniture/gravel loads and Home Depot stuff too... And I can finally four wheel at least moderately somewhere :woot:.
  11. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    sound like a good deal. if i was into dodges i wouldnt hesitate:D
  12. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i think any good running truck should get at least $1000, it seems this one is better than that for its age, id say u got a good deal. post up pics!!
  13. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    cummins or gasser?
    good deal either way...
