whats the difference between dodge and gm 60's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jackedjimmy350, Oct 11, 2002.
  1. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    whats the difference between dodge and gm 60\'s?
    just wondering cause i have a good line on a cheap dodge 60. /forums/images/graemlins/thumb.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Re: whats the difference between dodge and gm 60\'s?
    The hub is the only difference.
  3. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    And maybe the spring pad position but that is easy to fix right? /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  4. jackedjimmy350
    Oct 20, 2000
    3,141
    yeah, if the pads are different, i have an oklahoma monkey wrench that can fix it real quick /forums/images/graemlins/thumb.gif /forums/images/graemlins/wink.gif
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I've got a Dodge housing w/Ferd outters... and nothing was moved for it to fit. A word on the Ferd outters: If you plan on using 15" rims, DON'T get them. The dual piston calipers cannot be ground down to fit inside the rim. /forums/images/graemlins/frown.gif
    Just my .02! /forums/images/graemlins/grin.gif
    -Dan
  6. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    also think the drag link mount's from the bottem up on dodge.
    dave
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    hubs can be the same other then the stud size
    moving the spring perches is not an easy task unless you are talking rear axle
