Whats the difference between open and closed knuckle D44's?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85scottsdale, Jan 6, 2004.
  1. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Whats the difference between open and closed knuckle D44\'s?
    I need some educatin', i'm curious to know the difference between a open and closed knuckle Dana 44 of the half-ton variety.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Re: Whats the difference between open and closed knuckle D44\'s?
    I don't know much about a closed nuckle 44 but I do know that the open style knuckles are stronger and easier to take apart. Plus you can see the u-joint.
    One thing with heavy farm equipment is that on planetary axles (4 or 5 ton, and closed knuckle) the axle tube will crack at the nuckle when they have a constant heavy load on them sometimes.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Closed knuckle, not the ball socket like joint(axle joint is included), this is the weaker knuckle.
    Open knuckle, axle joint is open, much stronger knuckle:
  4. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Closed knuckles have fluid in them to lubricate the joint. They are prone to leaking which leads to failure. Stay away from them. /forums/images/graemlins/tongue.gif
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    These are 2 good point the guys gave but the most important issue is the closed knuckle axle has less room inside so they use smaller joints which are weaker.
    /forums/images/graemlins/thumb.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    '70 was changeover year over to open knuckle btw, some 70 are open and some were still closed, hit and miss, 70 was also the year the axles widened under GM trucks blazers burbs
  7. 85scottsdale
    Dec 22, 2003
    283
    Lewisville, NC
    Great! Thanks for the info guys, i'm am not a little more educated!
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Great! Thanks for the info guys, i'm am a little more educated!
    That is what is so great about this site and all these guys!
    There is so much knowledge that can be gained here that it can make your head spin and smoke pour out your ears. /forums/images/graemlins/thumb.gif
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I lost my ears a long time ago from the smoke pouring out /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
