What's the difference?
Discussion in 'The Garage' started by babyburb, Apr 18, 2007.
  1. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    I see alot of post talking about putting in a 2wd steering box instead of a 4wd? What's the advantages?
  2. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    The only reason people install the 2wd box is for a crossover steering modification. The 2wd box uses a different sector shaft to allow the correct pitman arm for the shaft. Check out this catalog page from Offroad Design for more info on the swap.
    http://www.offroaddesign.com/Dana60crossover.htm
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yes , for crossover steering .
    2wd box = fully splined , the pitman arm can be clocked anywhere .
    4wd box = splined partially and set screwed ( cinch bolted actually ) , the pitman arm goes on one way only .
